Multiple T560 cutting at the same time?
Tremdall
Post: # 46913Unread post Tremdall
Thu May 18, 2017 7:08 pm
Is there a possibility to have multiple T560 lathes cutting synchronized at the same time?
Can it be done through an added midi control together with a DAW? Or are there people who simply use a remote control connected to all lathes? Sorry if it has been asked before, could not find it in search.
MEGAMIKE
Re: Multiple T560 cutting at the same time?
Post: # 46915Unread post MEGAMIKE
Fri May 19, 2017 5:53 am
hi
yes ...but one record has an extra line or two, the audio is from one source ..
one head goes down then the next head goes down(be carefull) then with 2 arms and hands do the lead ins.press play..when there is a space in between songs then again with both hands do your spaces..your records should have the same consistency and look etc..
...this is not true sync though ...
daw midi ?/ well you will have to build something to add to ur lathe??..
when i do have 2 lathes at the same time cutting its mostly 2 jobs(audio)..
megalove
TheCrates
Post: # 46917Unread post TheCrates
Fri May 19, 2017 10:34 am
Yes it absolutly works. You can completly automate multiple t560 with midi of your daw, stepper motors and a teensy or arduino type boards.
This includes head down, lead in, cut, space between tracks, lead out, head up, move head back to start position.
A lot easier and less hardware needing solution instead doing it with relais, buttons and switches.
You find examples in lathetrolls and youtube.
SueDenim
Post: # 46918Unread post SueDenim
Fri May 19, 2017 11:03 am
I'd really like to see an example of head down/up automation.
Done quite a bit myself but never seen that!
Sillitoe
Post: # 46919Unread post Sillitoe
Fri May 19, 2017 11:20 am
Snippets from a vid of my old setup with the Caruso cutting automated locked grooves. Down, up, brush. :lol:
Takes a little time to fine tune, there's also better automation mechanisms available to modify a t560 with than shown here (including a vacuum :lol: ).
https://instagram.com/p/BDi1FWdEH0G/
https://instagram.com/p/BDi0fDUkHyz/
James
TheCrates
Post: # 46920Unread post TheCrates
Fri May 19, 2017 12:31 pm
Hahah word James, you came in mind besides duophonic and vinylrec when i mention it. :D
My man Tim from Timitus Records has a servo based head up and down also variable suction distance controller. I seen some ole videos on facebook.
SueDenim
Post: # 46921Unread post SueDenim
Fri May 19, 2017 1:15 pm
Thanks for the tips guys!
Just found this vid from Tim which seems to show the head lift automation mech: https://youtu.be/jddgylg-H2s
Would like to build something like that myself so will try to contact Tim for a chat...
Tremdall
Post: # 46922Unread post Tremdall
Fri May 19, 2017 2:52 pm
That is amazing and exciting news. It seems I have some study to do... Especially since this is the first time I heard about the word Arduino :D Great site Trolls!
Tremdall
Post: # 54930Unread post Tremdall
Sat Feb 08, 2020 3:30 am
Hi Sue,
did you ever got information about the automated head lift mechanism?
I'll be very interested in any information about automations, arduino set ups, how to build arduino automations, etc.
Tremdall
Post: # 54931Unread post Tremdall
Sat Feb 08, 2020 3:36 am
Do you have links to any information concerning t560 with midi & arduino ?
Post: # 54999Unread post tragwag
Wed Feb 12, 2020 6:29 pm
just popping in to say I cut on two T560s at the same time, all manual.
the trick was combining two hoses into one chip jar and maintaining suction
Tremdall
Post: # 55033Unread post Tremdall
Fri Feb 14, 2020 1:38 pm
Thanks Tragwag!
No extra complications?
It sounds doable indeed.
But I'm also still interested in automating things, even for one T560.
I can imagine it's pretty simple to make this through arduino, for someone who is aquainted with it.
Post: # 55036Unread post tragwag
Fri Feb 14, 2020 4:20 pm
no issues aside from keeping track of the chip jar more often, and fighting static twice as hard with the two chip tubes combining into one
