Vanrock Recorder E-101
ilium
Post: # 47997Unread post ilium
Tue Oct 03, 2017 8:33 am
I recently acquired a Vanrock and most everything about it seems self explanatory except the ENDING function. From what I can gather this will do a run out groove and then a locked groove to keep the stylus from skating across the center into the spindle. The lockout is in a fixed position but mine when it goes to the locked groove it doesn't manage to lock it.. it just keeps slowly incrementing the groove I guess until it crashes into the hold down weight.
Any suggestions on how to fix this?
ilium
Re: Vanrock Recorder E-101
Post: # 48028Unread post ilium
Thu Oct 05, 2017 6:41 pm
I'm considering unmounting the head from the Vanrock chassis adding longer wires and mounting it on a separate lead screw with a fullsize turntable to cut mono 12" records.
