VR cutting problem!Help
Re: VR cutting problem!Help
Post: # 49248Unread post tragwag
Tue Feb 06, 2018 3:42 pm
looks like your height might be wrong. the same place you adjust the head angle is where we adjust the height.
mine sits about 75% of the way up on both my lathes
Ben
Post: # 49249Unread post Ben
Tue Feb 06, 2018 4:01 pm
Im wondering if its because your turntable is not the same height than a sl1200 mk2....
Maybe...
Tremdall
Post: # 49251Unread post Tremdall
Tue Feb 06, 2018 10:33 pm
Are you doing these tests on an mkII? Or do you still have the mkIII?
If it's the last one, big chance your stylus is again damaged.
JHL
Post: # 49252Unread post JHL
Tue Feb 06, 2018 11:04 pm
Hey Tragwag,
If i adjust cutterhead higher,my cutterhead couldnt parallel to the blank..only that low can paralle to the blank..
Hey Ben,
the height is around 8cm,same to mk2?
Hey Tremdall,
I havent switch to MK2 yet,but i have not cut anything yet...just adjust the angle, height and weight..
torykay
Post: # 49259Unread post torykay
Thu Feb 08, 2018 4:16 am
I have a question to You. Did You unscrew isolation feet from Your Technics turntable? I think You didn't do it!
Post: # 49274Unread post tragwag
Fri Feb 09, 2018 12:35 pm
yeah I was gonna mention that too. Because I use the SP-10 and SP-15, I've had to put some cardboard underneath to raise them up to the level the 1200 sits with the little feet. that's also why those feet are adjustable.
JHL
Post: # 49284Unread post JHL
Sat Feb 10, 2018 7:36 am
I do find out some problem on turntable feets,it seems not 100% fit the lathe base,it may cause by my 1200mk3 turntable?
anyway,my 1200mk2 on the way..
handcut
Post: # 49285Unread post handcut
Sat Feb 10, 2018 10:24 am
Hmmm.... Is everything level??? Check the table/bench/whatever it is your VR sits on with a spirit level. Side to side and front to back. Then check your lathe bed (the large base) is level, again side-side/front-back. Then check your turntable is level. Once everything is level, adjust the cutterhead to set cutting angle, then set the weight/depth. Good luck!
JHL
Post: # 49292Unread post JHL
Mon Feb 12, 2018 7:29 am
Hello Everyone!!!
important update!I just done my first cut after change the stylus,
I set turntable and lathe base to the level,countweight on 46g,and i switch the black plastic up on the damper while cutting
the magic is happening,no wow&flutter and all the noise is gone!!!you have no idea that how exciting i am right now!!! :shock: :shock: :D :D
although the volume is not loud enough for now,and the groove is not deeper enough,i almost crying for the first cut,thanks all of you sooooo much!
i will update the audio on soundcloud soon...
Post: # 49317Unread post tragwag
Tue Feb 13, 2018 12:40 pm
excellent! there you go, cheers
Tremdall
Post: # 49348Unread post Tremdall
Wed Feb 14, 2018 5:10 am
Sounds good to me. Well done...
SueDenim
Post: # 49350Unread post SueDenim
Wed Feb 14, 2018 9:23 am
Nice one! :D
JHL
Post: # 49362Unread post JHL
Thu Feb 15, 2018 3:31 am
thanks all of you for the paitent and help :D so happy i am a true begineer of lathe cut now! Happy Chinese New year here!!!wish everyone have good cut!
Post: # 49364Unread post tragwag
Thu Feb 15, 2018 4:27 pm
happy new year! a great start :D
Ben
Post: # 49430Unread post Ben
Sat Feb 24, 2018 7:25 am
That's a freaking good news !!
I'm happy for you, one thing that helped me a lot.... always triple check everything before starting a cut even if you're used to it , what lead me to scrap blanks or diamonds... was always me thinking " I know my sh*t, that's how we do it " and then you forget a little detail ... and ouch on the wallet.
Keep us in the loop of your progress it's cool to hear from you!!
Discomo
Post: # 58148Unread post Discomo
Sun Mar 28, 2021 7:11 am
JHL wrote:
Tue Jan 16, 2018 7:16 am
am i bought the wrong mineral oil?the one i bought is transparent but it seems everyone are yellow..
Updating on an older post of @JHL
I'm not sure what the name is of the dashpot oil (I believe it was mentioned on LT sometimes in an older post)
But I recently changed the oil for the first time in almost 4 years. I guess that's a bit too long, but no problems though.
I include a photo on which I removed the old oil with a syringe and an added small tube (part of an audiocable), in order to get the last drops out of the dashpot & not having to take apart the dashpot. This worked fine.
To add new oil the syringe sold by Souri worked fine without an additional tube.
Anyway, the oil itself is very thick. Think consistancy of very thick sugar-syrup. When you would flip the dashpot upside down, the oil would basically not drop within a minute at least, thát thick.
The older oil had a smell of older motoroil. The new oil is without a smell.
For the exact name of the oil you can have a look on this site, but it's def thicker than the kind of oil you normally put in yr car.
Sucking up the old oil with a syringe+tube
