320 style embossing cones?
Jccc
Post: # 49213Unread post Jccc
Sat Feb 03, 2018 7:50 pm
has anyone made a 320 style shank for embossing?
Re: 320 style embossing cones?
Post: # 49215Unread post piaptk
Sat Feb 03, 2018 9:41 pm
Send me some dead ones and I'll get some made for you.
socialroots
Post: # 49216Unread post socialroots
Sat Feb 03, 2018 10:44 pm
Tenshun,been testing out some of PIAPTK sapphire cone as of late,took me about 6 cuts to fine tune my weight n angle settings on my lathe, once i got there,the results were very pleasing to my ears. I,ve embossed to pc before with the tungsten cones ,which i thought was pretty good already,but with the sapphire cones my tunes got some extra brightness to the sound n the grooves looks cleaner with less horns,more consistent tracking on playback. You should go ahead and give a new life to your worn out sapphires,i think its a great way to repurpose dead stylis.
This has got me thinking about how well would diamond work as embossing cones?
Maximum respect,
Patrick
P.s Teshun,when you gonna do an Asian tour?
Post: # 49219Unread post piaptk
Sun Feb 04, 2018 10:39 am
Diamond doesn't work for embossing cones for some reason. I know because I accidentally put a diamond stylus in with the stack of sapphires. Rich sharpened it, but it sounded awful.
socialroots
Post: # 49220Unread post socialroots
Sun Feb 04, 2018 11:06 am
Mike,thanks again for hooking me up. Wonder why diamonds dont work as cones for embossing? Maybe Steven has got some insight on this and probably doesnt have diamond emossing cones as one of his stylis for sale cuz he probably came to the same conclusion.
Maximum respect,
Patrick
Post: # 49273Unread post tragwag
Fri Feb 09, 2018 12:33 pm
not to derail but I had luck before with a regularly faced diamond stylus, using it like a backwards sapphire.
Jccc
Post: # 49280Unread post Jccc
Fri Feb 09, 2018 1:19 pm
I will try out a old sapphire needle backwards technique and see if i can get good results.
I have been having really good results with the tungsten cones on my fairchild head so i was thinking if i could modify the tungsten cone to somehow mount on a cutting head (Neumann mono head) with a 320 stylus holder i will have even better frequency response.
socialroots
Post: # 49283Unread post socialroots
Fri Feb 09, 2018 10:43 pm
tragwag wrote:not to derail but I had luck before with a regularly faced diamond stylus, using it like a backwards sapphire.
greetings Tyler,just wondering when you used the diamond to emboss,was the tip worn down or was it stil in good cutting condition? I tried with my 1st diamond,but the groove was looking like a mix of embossing and slight cutting,even some very fine material was being removed.this was with the myshank blanks,didnt try pc cuz the styli was still very new and didnt want to chance ruining it prematurely. Lean back?
Maximum respect,
Patrick
Post: # 49288Unread post piaptk
Sat Feb 10, 2018 7:17 pm
If you've been getting good results with tungsten, you will love the sapphire embossers. The stone seems to take a better point and the aluminum shank allows more of the High End to reach the tip, where as the dense tungsten kills a lot of vibration on the way down. Sapphires have a lot more clarity in the high end.
jjwharris
Post: # 49291Unread post jjwharris
Sun Feb 11, 2018 4:46 am
What's the frequency drop off point for your sapphires piaptk?
With tungsten I'm finding its quite a drastic drop from 10khz on polycarb., Im curious as to if its the polycarb or the tungsten cone.
Post: # 49316Unread post tragwag
Tue Feb 13, 2018 12:39 pm
Maximum respect,
Patrick
yeah! I was leaning back a whole lot, as much as the 6N would let me.
jjwharris wrote:What's the frequency drop off point for your sapphires piaptk?
In my limited experience with the cones, it was the tungsten causing the dropoff, I had fine success with the same settings/different stylus on polycarb
jjwharris
Post: # 49449Unread post jjwharris
Sun Feb 25, 2018 10:15 pm
Right, I'm gonna try some aluminium cones, I'm hoping they will last at least long enough for a quick sweep
jjwharris
Post: # 49470Unread post jjwharris
Tue Feb 27, 2018 12:03 am
aluminium cones, ground to a 90 degree point - seem to work as well as tungsten.
I ended up asking someone to make a glass embossing cone, will be interesting to see how that turns out.
jjwharris
Post: # 49471Unread post jjwharris
Tue Feb 27, 2018 5:03 am
After playing around with it a bit, I think it could be a bit better than tungsten, the wear on the tip is going to be the issue.
It did raise my resonant frequency a bit, which no doubt helps.
