What is the cheapest lathe that will give you decent audio?
Benholister
Post: # 49429Unread post Benholister
Sat Feb 24, 2018 6:31 am
I want to get a good lathe that will be able to cut good recordings and not sound like its from the 60s. Do you guys have any suggestions on getting a decent lathe that will cut some good audio and what do buy with it? Thank you
handcut
Re: What is the cheapest lathe that will give you decent aud
Post: # 49432Unread post handcut
Sat Feb 24, 2018 10:01 am
Vinyl Recorder
Benholister
Post: # 49441Unread post Benholister
Sun Feb 25, 2018 6:00 am
thank you! is there any other way to get it besides going to germany?
boryo
Post: # 49444Unread post boryo
Sun Feb 25, 2018 8:36 am
No, unless you get it used from someone else but then you don't have any support from Souri.
The Shank
Post: # 49447Unread post The Shank
Sun Feb 25, 2018 12:06 pm
boryo wrote:No, unless you get it used from someone else but then you don't have any support from Souri.
Useless, we are in 2018
http://www.myshank.com
skype : steven.myshank
* Resharpening services
* Blank records
* Cutting lathe
Benholister
Post: # 49455Unread post Benholister
Mon Feb 26, 2018 6:34 am
do you sell VR lathes?
The Shank
Post: # 49458Unread post The Shank
Mon Feb 26, 2018 7:09 am
Yes sometime, when I get some second hand
* Blank records
* Cutting lathe
jesusfwrl
Post: # 49560Unread post jesusfwrl
Mon Mar 05, 2018 8:46 am
What is the cheapest car that can carry my stuff and doesn't feel like it's from the 60's?
The answer will depend n how heavy your stuff is and how much space it takes, what terrain you will be driving on, how far you want to drive and how often, how fast you expect to get there, how comfortable you expect to feel while driving, how much you vale your life and well being, and how much money you are willing to spend for fuel, maintenance repairs, and the car itself.
If your stuff weighs in at 40 tons, takes up 12m2, you want to drive on rocky mountain, 10 000 miles per day every day, at 120mph, while feeling like you're sitting in your living room, while being super safe, getting 15000 mpg, zero maintenance, and all this for five dollars, it simply won't happen. What do you define as good audio quality?
Is the Neumann SX68 cutterhead not up to your standards, since it is from the 60's? How about a VMS66 lathe? Or a Scully with a Westrex 3D head? Lo-fi 60's crap...?
powerstrip
Post: # 49766Unread post powerstrip
Mon Mar 19, 2018 9:59 pm
jesusfwrl wrote:Is the Neumann SX68 cutterhead not up to your standards, since it is from the 60's? How about a VMS66 lathe? Or a Scully with a Westrex 3D head? Lo-fi 60's crap...?
Yes exactly. I think what he is looking for is called a CD burner.
expect 5-10k depending on who you are dealing with
concretecowboy71
Post: # 50165Unread post concretecowboy71
Fri Apr 27, 2018 12:16 pm
Uh...records from the 60s were cut on pretty damn good stuff. So good that records are still made using them.
