Some questions about record pressing.
The_House_Records
Post: # 47579Unread post The_House_Records
Thu Aug 17, 2017 11:14 am
Hi guys, i'm a new user on the forum and I have a few questions about vinyl record pressing.
How cheap could you get a record extruder and record trimmer used?
Also, mossboss was suggested that you need ALOT more than just a record press, extruder, trimmer, boiler, pumps, compressors, and water tanks. What gives? Based on what I was told at Third Man Records, It seemed like a relatively simple process with relatively simple equipment.
Thanks. :D
The_House_Records
Re: Some questions about record pressing.
Post: # 47582Unread post The_House_Records
Thu Aug 17, 2017 3:42 pm
I'm 11 BTW
Post: # 47636Unread post Aussie0zborn
Thu Aug 24, 2017 6:03 am
Thanks for posting. Good to see you're interested in this industry. You might like to think about studying engineering or business management or both. It's seems that might suit your interests. A
Any industrial process is often more complex than it seems.
