Monitoring While Cutting Master Lacquer
SUNBEARS
Post: # 35522Unread post SUNBEARS
Fri Jun 12, 2015 2:34 pm
Hey Trolls, total noob question, but do you all monitor your cuts while cutting a master lacquer?? I know that acetate degrades a little bit with each play, so I would assume that it's wise to not monitor your cut, but only monitor your test cut (with a playback head in the groove).
If you don't monitor while cutting, how do you maintain quality control and assure that your cut plays through??
Thanks for your infinite wisdom.
Cheers,
J
leo gonzalez
Re: Monitoring While Cutting Master Lacquer
Post: # 35526Unread post leo gonzalez
Fri Jun 12, 2015 10:23 pm
experience
Sent from my iPhone using Tapatalk
leo gonzalez
Post: # 35527Unread post leo gonzalez
Fri Jun 12, 2015 10:34 pm
having an jdea of all the things that can mess up the transfer and be alert and ready to tackle all those issues before they happen in the cut.
Post: # 35528Unread post opcode66
Sat Jun 13, 2015 12:07 am
I don't know any professional cutters who play master lacquers. You do plenty of test cut. And, play that. But, never play the master. As long as everything went without error in the cut, and the reference cut sounded fine, then the master should be A-Ok. But, the final determination, which I feel too many folks skip over judging by some of the cuts I've inspected, is to put the master cut under the scope and read the entire side visually. So many imperfections can be caught this way. I can, if you like, post scope images of a cut that should have never, ever, ever gone to press. The stylus was chipped. No center line at all in any groove on either side. Obviously this big name cutter was rushing. Obviously, they didn't look at the 7" masters under the scope. Otherwise, this would have been rejected after cutting a a new stylus installed. FYI, the cut had unacceptable background noise due to the playback stylus constantly scraping the bottom of the groove, which should have never happened.
pellegrino707
Post: # 35616Unread post pellegrino707
Fri Jun 19, 2015 4:58 am
Hi opcode666, would be very useful to see some pictures indeed!
Which is the magnification of a regular Neumann microscope? 40x?
Post: # 35747Unread post opcode66
Sun Jun 28, 2015 3:52 pm
Directly from the Neumann manual
Watch these videos to see grooves from the Neumann and my cutterhead Project Bladerunner.
Bladerunner out of phase
Bladerunner in phase
