Frequency Response: Lacquer v Pressing
Moderators: piaptk, mossboss, Aussie0zborn, tragwag, Steve E., Simon
Re: Frequency Response: Lacquer v Pressing
Unread postby jjgolden » Fri Apr 08, 2016 11:21 am
Does anybody know if polishing the mothers/removing horns affects high end?
I have no idea
JJG
jjgolden
Unread postby Dub Studio » Fri Apr 08, 2016 11:39 am
Greg Reierson wrote:Everything in the chain between the original source and signal to the head could be though of a as pre-emphasis (not to mention RIAA...) in an attempt to make the playback sound as close to the source as possible, but it's a moving target. The variation of different geometries and especially different cartridges far outweigh any differences between lacquer and vinyl. This is not a linear medium where a specific offset will always give the desired results. The best you can do is aim for the middle hope the end user has a system that can extract all of the care that you put into the grooves.
I concur for the most part.. I am always aware of the medium I am mastering for, but I handle a range of media so I use a two-step approach. The first half of the chain will be for the sound, and the second half will be for the medium.
For instance I apply the de-esser post RIAA in the second half of the chain, because that's where it makes most sense to me to place it. I cut acetate dubs as well as vinyl dubs, and they each have a very distinct sound of their own, so I have to adjust the RIAA pre-emphasis accordingly. I would not consider these stages until after I had achieved the sound I wanted to achieve coming out of the monitors because I don't want to muddy the waters. Not to mention needing to run off digital masters for reference before and after cutting etc.
Of course, I am happy to accept that there are horses for courses, and comparing apples and oranges is the analogy I often refer my clients to when their vinyl doesn't sound "exactly like" the digital versions. But really what I am looking for here is a baseline difference between playing a lacquer, and a pressing from that exact same lacquer, using the exact same playback set up.
Dub Studio
Unread postby gold » Fri Apr 08, 2016 3:21 pm
mossboss wrote:Now take a 45 single and place it over that area on a 12" record one will find that it falls within these area assuming that it has around 3 minutes of. Music on it
Often people wonder why 45,s are brighter cleaner and very much alive wel that's the reason.
On the overpriced piece of plastic I have from Columbia for measuring record dimensions, the spindle is zero and the outside diameter is 11" and change. Same thing for the other things I have. The RIAA spec documents I have list it the same way. The outside diameter of the record is determined by the way the trimmer is set up.
gold
Unread postby sat159p1 » Sun Jul 17, 2016 5:14 pm
Question: Do we need to make songs that are near the center of a record a bit brighter to compensate hf loss? Or maybe this hf boosting will result only with more distortion? Maybe we need to turn hf down on these last tracks?
sat159p1
Previous
Return to Vinyl Mastering, Lacquer cutting, Pro's and others
Who is online
Users browsing this forum: No registered users and 5 guests
