Cry For Help - DS601 Manual
- guy electric
Hi Trolls,
Does anyone out there have, or have access to, a manual for the Ortofon GOS601 Cutter Amp? I am trying to line them up to a DSS601 Cutter Head.
- dubcutter89
Re: Cry For Help - DS601 Manual
Hi!
I guess you already tried contacting etec or Mr Davis?
What is the Problem? Wiring? Dialing in FB? Missaligned amps?
Rocking Bridge Rocks!
Lukas
Lukas
- guy electric
Thanks Lukas,
I think we've got copies of anything that Sean Davies had, but will try emtec. I'm not directly involved with the restoration/repair myself, so need a bit more info. I think the main thing is dialling in FB at the moment...
G
G
- dubcutter89
Well, if the amp is well maintained (a good tube amp service tech should be able to check out, or maybe folks at ART-audio related technology, but you know them as well..) then it should be quite straight forward - check polarity, dail in fb as wanted (probably a little less on the early tube system as the regulation loop is simpler than on the later transistor system...), set drive/monitor levels
Also ortofon claimed different FB setings for different styles of music - I really love that oldschool tech haha!
Lukas
Lukas
