DIY vinyl with silicone molds and casting resin
ROLANDJAYS
Re: DIY vinyl with silicone molds and casting resin
Post: # 33060Unread post ROLANDJAYS
Thu Jan 08, 2015 1:15 am
Getting great results from mold making is not easy.
the hard part about it is you only get 1 shot at it.
so you need to think out your plan very well.
take a look at these Grampian and Audax parts I made a few months ago.
both parts were molded as you see them.
Jccc
Post: # 33076Unread post Jccc
Thu Jan 08, 2015 8:41 pm
You guys get very good results. I always have a problem with air bubbles messing up the resin once it has dried.
recordboy
Post: # 33086Unread post recordboy
Fri Jan 09, 2015 12:04 am
WOW cool...
Yeah I understand the difficulty involved for sure. Not to simple... Great work...
Cheers,
recordboy
ilium
Post: # 47973Unread post ilium
Sun Oct 01, 2017 9:02 am
I've been experimenting with casting records from resin as well. I have a degasser for the rubber mold (I'm using Smoothon 30) which definitely helped reduce surface imperfections in the mold but I'm still getting too many pops in the resulting cast. I'm not sure if the pops are coming from just the mold or from air in the poured resin. I'm currently using a fast setting resin but I also have a polyester resin but it seems to take forever to cure because of how thin the record is and it smells terrible (I pour it outside with a mask).
