Tone arm mounting ideas for Presto 8n
trailerparkjesus
Post: # 49156Unread post trailerparkjesus
Mon Jan 29, 2018 10:29 am
Curious if anyone has mounted a tone arm for instantaneous monitoring during the cut? My 8n is in the original console
trailerparkjesus
Re: Tone arm mounting ideas for Presto 8n
Post: # 49254Unread post trailerparkjesus
Wed Feb 07, 2018 12:09 pm
Anyone? :shock:
Gridlock
Post: # 49255Unread post Gridlock
Wed Feb 07, 2018 1:13 pm
ilium
Post: # 49256Unread post ilium
Wed Feb 07, 2018 1:29 pm
I have a 6n and I'm also trying to find a tone arm I can easily add to my setup... I might go so far as to try to 3d printing one
ilium
Post: # 49257Unread post ilium
Wed Feb 07, 2018 2:36 pm
trailerparkjesus wrote:Curious if anyone has mounted a tone arm for instantaneous monitoring during the cut? My 8n is in the original console
You might find this thread interesting
https://www.lathetrolls.com/viewtopic.php?f=1&t=927
Post: # 49278Unread post tragwag
Fri Feb 09, 2018 1:15 pm
my 6N came with an Audax KT-16, but the way it swings makes it impossible to monitor while cutting.
not too familiar with how the 8N is laid out, but I'm guessing a 16" tonearm would do
trailerparkjesus
Post: # 49503Unread post trailerparkjesus
Thu Mar 01, 2018 5:31 pm
Thank you everyone... I have an old tone arm that might do the trick but mounting it is the questionable part. Was going to make a round base for it that raises it to platter height and tracks right in front of the cutter head (kinda sketchy how close it gets!)
Was hoping someone successfully did it and had pictures
EpicenterBryan
Post: # 49506Unread post EpicenterBryan
Thu Mar 01, 2018 11:08 pm
Here is my thread on setting up a tone arm on my 8D.
https://www.lathetrolls.com/viewtopic.php?f=15&t=6655&p=43305&hilit=presto+microtrak#p43305
You can mount the tone arm directly on your 8N, and I could not... But you will find some interesting things in the thread.
B
