Deep Grooves Mastering - VMS70 Carriage Arm Switch Mod
Post: # 30333Unread post opcode66
Tue Jun 03, 2014 1:37 am
The VMS carriage arm contains a reed switch. These switches can get bent out of shape over time. If it gets bent, certain function will no longer happen. For instance, the full stop when you push the carriage lever back will no longer work if the switch get deformed in a particular way. Also, if the normally closed contacts are not made when the lever is up or forward, your leed-in groove and end grooves wont trigger either. This was happening on my lathe and I troubleshot a lot of cables and cards before finding it was simply this reed switch not making it normally closed contact.
As usual, I decided to come up with a better solution. I 3D designed and printed a bracket that holds a microswitch. This new assembly replaces the original reed switch. And, it works great! Check it out. For sale at http://www.deepgroovesmastering.com
Also, FYI, music by Opcode66 :D
misjah
Re: Deep Grooves Mastering - VMS70 Carriage Arm Switch Mod
Post: # 36174Unread post misjah
Thu Jul 23, 2015 1:54 pm
got one from Todd. fast delivery and install took literally 5 mins. def recommended :)
cheers,
Misjah
Post: # 36202Unread post opcode66
Fri Jul 24, 2015 10:20 pm
Thank you very much for your support, Misjah. I really appreciate it! Glad the installation went so smoothly. It was in obviously capable hands... :-)
Cheers!
