Wanted - Presto 8dg lathe drive pulley x 2
Simon
Post: # 46929Unread post Simon
Mon May 22, 2017 6:53 am
Look for the two brass, bronze drive pulleys, original or repro
Maybe someone could get a local engineering company the copy theirs, happy to pay.
Happy to learn something new.
EpicenterBryan
Re: Wanted - Presto 8dg lathe drive pulley x 2
Post: # 46945Unread post EpicenterBryan
Mon May 22, 2017 9:50 pm
I have a spare original brass one for the overhead side of an 8D. You will need to check if it is the same as the 8DG.
The Aluminum one shown mounted on my lathe was custom made for the previous owner to have different pitch combinations. It works works fine for me.
Shoot me a PM with your absolute best offer and I'll think about it... I'm always a buyer and rarely a seller.
Bryan
audiocarver
Post: # 46998Unread post audiocarver
Sun May 28, 2017 4:55 pm
Hi Bryan,
What does the bronze "C" do around the turn table shaft pulley? Does it clamp at the bottom of the TT bearing housing or something?
Regards,
Andy
Simon
Post: # 52016Unread post Simon
Fri Jan 04, 2019 10:16 am
I am interested if you still have it
Simon
Post: # 52029Unread post Simon
Sat Jan 05, 2019 9:19 am
It seems I will need the bronze c bearing adaptor as well
Simon
Post: # 52075Unread post Simon
Mon Jan 14, 2019 3:53 pm
Pics
Simon
Post: # 52076Unread post Simon
Mon Jan 14, 2019 3:54 pm
More
EpicenterBryan
Post: # 52083Unread post EpicenterBryan
Tue Jan 15, 2019 12:00 pm
I'm confused. Why is it that you want to change over to pulleys?
Isn't the 8dg direct drive? Mine is a rim drive 8D so I really don't know how the pulleys come into play with the direct shaft.
In your photos I don't see the direct drive shaft.
Bryan
Simon
Post: # 52085Unread post Simon
Tue Jan 15, 2019 2:43 pm
The 8dg was originally a pulley like yours. What I have a cross between an 8DG and a 8DGV - a prototype. I was thinking of changing it back to the standard 8DG
Post: # 52098Unread post piaptk
Thu Jan 17, 2019 12:17 am
I have an extra screw side pulley, but not a platter side pulley...
