Rietschle 7860 Dual Dry Running Suction Pump
We tried this once on full power with a Souri Lathe and it split the suction pot in half! Haha
Say goodbye to swarf issues with this!
It works but needs a rebuild as rotor gets stuck. Vanes look ok.
Cost thousands of pounds when new.
£250 plus courier - UK only! Weighs around 50kg
Needs rebuild!
Elmo Rietschle Heavy Duty Dual Suction Pump
Re: Elmo Rietschle Heavy Duty Dual Suction Pump
Wahahaha, this is overload 101. Epic!
We use a slightly newer version of this. Pretty much the same but has a plastic enclosure over the whole thing. You can regulate the suction with the knobs on top!
They're suprisingly quiet also! Much better then a noisy inefficient Hoover!
