Cutting Lathe Precision Platter - SP10 - SP1200
TheCrates
Post: # 47612Unread post TheCrates
Mon Aug 21, 2017 12:44 pm
Hello,
im currently developing and preparing my precision platter, anybody interessted? I didnt start calculating, but the more i produce, the cheaper it can get.
Dimensions:
Diameter: 14" (355,6mm / 35,56cm)
Thickness: 8mm
Spindle hole: 7,1mm
Parallelism: 0,01mm / 0,02mm
Material: Steel
Surface: Chrome coated
Weight: +3,3kg
Shipping: Yes
Price: Probably around 200€
Cheers,
Crates
Re: Cutting Lathe Precision Platter - SP10 - SP1200
Post: # 47615Unread post tragwag
Mon Aug 21, 2017 4:53 pm
sounds great, any availability to add platter hold down suction?
TheCrates
Post: # 47618Unread post TheCrates
Tue Aug 22, 2017 9:57 am
It would be possible, but i keep it simple and cheap with a clamp on the spindle.
Just want to have a additional rotation mass, concentricity, and a slower /even heating of the blanks meanwhile cutting.
TheCrates
Post: # 48659Unread post TheCrates
Wed Dec 06, 2017 10:28 am
Update: Finally in the making, paid in advance for two, 600€ to get it a bit cheaper. One is available for sale in case youre still interessted.
Should be ready mid January the company said.
Pictures will follow as soon ill recieve it. Cheers, Crates.
