Grampian c/h
bpatric
Grampian c/h
Post: # 47689Unread post bpatric
Thu Aug 31, 2017 10:26 pm
Hey...anyone have info or docs on a Grampian c/h cutterhead? Thanks...
Soulbear
Re: Grampian c/h
Post: # 47690Unread post Soulbear
Fri Sep 01, 2017 3:35 am
Hi There,
Here's some Bracket/Mounting detail that may be useful.
Regards :wink: :P :D Soulbear
Soulbear
Re: Grampian c/h
Post: # 47691Unread post Soulbear
Fri Sep 01, 2017 3:42 am
Hi There,
Almost forgot this too, silly me!! As far as I can tell, your "Laydown Grampian" is a "Variant" but the "Techie Stuff" may well still be relevant.
BBC Type B Cutterhead (Grampian).pdf
bpatric
Re: Grampian c/h
Post: # 47696Unread post bpatric
Fri Sep 01, 2017 8:40 am
Thanks much! I'm likely going to sell this one...it came with an rca unit i bought and i have 2 other rca heads...one just rebuilt so i don't really need it. I assume this is a feedback unit which i don't have any experience with or an amp for.
Soulbear
Re: Grampian c/h
Post: # 47700Unread post Soulbear
Fri Sep 01, 2017 10:28 am
Hi There,
bpatric wrote: I assume this is a feedback unit
Well certainly, if it's configured like the one in those few Photo's, one pair of leads would be for Driving the Cutterhead, the other pair would be the feedback signal. Hope this Helps.
P.S.
bpatric wrote:it came with an rca unit i bought and i have 2 other rca heads...one just rebuilt so i don't really need it
I'm sure someone here on the forum would give your Grampian a good home. As well as RCA Lathes the Grampian's sit rather well on the UK built MSS Lathes too!!
bpatric
Re: Grampian c/h
Post: # 47717Unread post bpatric
Sat Sep 02, 2017 2:08 pm
It appears to be non feedback or modified or i can't see where the leftmost terminals go in the mechanism. The tabs are broken off on the back removeable plug. I get 5.6 ohm on the rightmost terminals...no reading on the left.
dubcutter89
Re: Grampian c/h
Post: # 47722Unread post dubcutter89
Sun Sep 03, 2017 8:17 am
Yes, the Grampian Type C is regular moving iron design without the "feedback" coil.
Type C/H should be the same just in the Horizontal case for mounting on some small desktop lathes.
if the magnet is strong should be a nice head for mono dubs..
If you want to get rid feel free to contact me :-)
Lukas
bpatric
Re: Grampian c/h
Post: # 47728Unread post bpatric
Mon Sep 04, 2017 9:22 am
Thanks for the info! When i get the lathe running I'll give it a listen..it's an rca 70c with11852 "recording attachment"...like the screen shot here.
dubcutter89
Re: Grampian c/h
Post: # 47731Unread post dubcutter89
Mon Sep 04, 2017 12:40 pm
RCA 70 are not as common as the presto and rek-o-kut Units but should give decent results when proper set up!
btw, heres a Little info i once took somewher from the net...
Lukas
bpatric
Re: Grampian c/h
Post: # 47744Unread post bpatric
Tue Sep 05, 2017 9:38 am
Fantastic! Thanks!
