Test tone for cutter head calibration
I made a series of test tones to cut and figured i'd share them. It goes 20hz to 20khz, each tone is -11db (sine). It's spaced out one tone per groove, with a silent groove between each tone.
1000, 20, 30, 40, 50, 60, 70, 80, 90, 100, 150, 200, 250, 300, 350, 400, 450, 500, 550, 600, 650, 700, 750, 800, 850, 900, 950, 1000, 1500, 2000, 2500, 3000, 3500, 4000, 4500, 5000, 5500, 6000, 6500, 7000, 7500, 8000, 8500, 9000, 9500, 10000, 11000, 12000, 15000, 20000
Made one for 33 1/3 rpm, and 45rpm.
33: www.djjaybird.com/TEST_TONES-33RPM.wav
45: www.djjaybird.com/TEST_TONES-45RPM.wav
Very surprised to find out that my presto 1-C cut the 20khz tone.
I plan on using this cut to balance my cutter head, by cutting it, playing it back, and recording it to my computer. Then I can see how even each tone is reproduced, and eq to compensate. I'm going for the flattest response i can get, trying to reproduce each tone exactly.
I hope this helps someone out. If anything the groove pattern looks cool!
- subkontrabob
Re: Test tone for cutter head calibration
Hi Jay,
Good effort with the test tones, thank you for sharing! I've been thinking about doing something similar.
To avoid this, Buchmann & Meyer developed an optical method to precisely measure levels of signals cut to disks. I started a thread on this topic to find out if people use this method, and maybe get some practical advice, but it didn't really pick up.......
It's good to keep in mind that in your proposed method the frequency response and distortion of your pickup will have an influence on the outcome.JayDC wrote: I plan on using this cut to balance my cutter head, by cutting it, playing it back, and recording it to my computer. Then I can see how even each tone is reproduced, and eq to compensate.
I got the idea from the presto 1-D manual. The correct way to do this test Visually would be to not use the riaa encoders. Just cut the grooves with no EQ at all, and you should see your heads true frequency response in the grooves.
- subkontrabob
I understand this, but I do not plan on using this cutter to produce recordings for the general public, I want to set this up to the type of playback pickup I'm using, and the DJ mixer I request in my contract.subkontrabob wrote: It's good to keep in mind that in your proposed method the frequency response and distortion of your pickup will have an influence on the outcome.
