mischmerz
Audio Chain With Compressor
Post: # 36875Unread post mischmerz
Fri Aug 21, 2015 8:34 pm
Howdy:
Please take a look at my audio chain. I integrated a compressor / de-esser with a side channel via equalizer. I don't want the equalizer in the signal path because it's a piece of junk that introduces distortions and clips easily. So - I use it to drive the compressor's side-channel instead. I edit all audios before cutting, the compressor should not have too much work and is pretty much a fail safe against some peeks I may have overlooked.
Is my thinking correct?
Michaela
