Soulbear
MSS Type CLED/3/3-Manual
Post: # 47002Unread post Soulbear
Mon May 29, 2017 12:23 pm
Hi Trolls,
I don't know if this is posted elswhere on the Forum, however, if not, some MSS Lathe Owners may find this Manual of Use:-
MSS Lathe Type CLED-3-3 Manual.pdf
Looking at both the Photo, and the Illustration within the PDF I think it's for a Lathe Type similar to this :-
Regards
:wink: :P :D Soulbear
Stevie342000
Re: MSS Type CLED/3/3-Manual
Post: # 47003Unread post Stevie342000
Mon May 29, 2017 1:12 pm
I have a copy of the earlier version of this which came with the modified Ferrograph Tape Decks as the source to drive the cutter amplifier and head somewhere but about to move so no idea where it is right now, somewhere safe not seen it in ages though. I think the manual I have is for the two speed version it is pre LP era but definitely post WWII. When Cecil Watts was still at the helm he was forced off his own board and corporation after GPO took it over during the war and over extended the credit to keep the BBC supplied in acetate master discs.
Not sure that he had any hand in this model as it may be after he left but not a lot of difference in the models over time only slight modifications such as microgroove and associated speed additions as well as RIAA post 1955. The manual I have covers the electronics that drive the cutter head as well, I assume then that there was a manual for the control electronics and another for the lathe part?
Soulbear
Post: # 47004Unread post Soulbear
Mon May 29, 2017 1:38 pm
Hi There Stevie342000,
Stevie342000 wrote: I assume then that there was a manual for the control electronics and another for the lathe part?
I think your'e probably correct about the Control and Lathe Electronics Manuals being separate, but I don't have any other copies of MSS related stuff. Truth to tell, I honestly can't remember where in the world I managed to download this from. I think I tracked it down when trying to do some research, in the course of my own MSS Lathe Ownership Misadventures!! Won't be doing that again in a hurry Te He!
Regards :wink: :P :D Soulbear
Stevie342000
Post: # 47005Unread post Stevie342000
Mon May 29, 2017 1:46 pm
