CD Centre Hole Adapters?
Boydie
Post: # 40979Unread post Boydie
Sun Feb 28, 2016 3:41 pm
When cutting on cd's what do you use as the inserts to play on a record player?
Any links would be great
Re: CD inserts
Post: # 41015Unread post tragwag
Tue Mar 01, 2016 3:16 pm
I know Mike PIAPTK has made his own, they work great and look snazzy.
http://piaptk.limitedrun.com/products/535023-cd-record-series-digital-analog-hybrid-discs
I've just glued or taped 45 RPM punchouts to the center, not elegant at all but gets the job done.
Fela Borbone
Re: CD inserts
Post: # 41017Unread post Fela Borbone
Tue Mar 01, 2016 3:33 pm
I use a m8 , filing a little inside and thermoshrink tube around....
Boydie
Re: CD inserts
Post: # 41120Unread post Boydie
Sun Mar 06, 2016 11:07 am
The 45 punch out is a great idea, I'll head along to a plumbing supplier and see what they hsve
alex rex
Re: CD Centre Hole Adapters?
Post: # 41124Unread post alex rex
Sun Mar 06, 2016 4:33 pm
for playback i do this:
i cut a 46 mm (in diameter) circle with a 7 mm centre hole out of card board (or thick magazin covers ...) and glue them onto the CD
for recording:
i use a 15 mm (in diameter) plastic round bar with a drilled centre hole (7,3 mm)
Soulbear
Post: # 41138Unread post Soulbear
Mon Mar 07, 2016 9:44 am
Hi There,
Has anyone had any joy with these 45 RPM Jukebox Record Dinkers + Centres or would they remove too much material and crack the C.Ds.??
Just a thought, they maybe worth considering eh? :wink: :P :D Soulbear
rsimms3
Post: # 41141Unread post rsimms3
Mon Mar 07, 2016 10:34 am
Pretty sure that dinker is only for UK 45s like pictured below. I believe it breaks the center out and doesn't actually cut. I don't think it has a blade and even if it did, the poly being so brittle it would break the CDs every time.
Soulbear
Post: # 41142Unread post Soulbear
Mon Mar 07, 2016 11:02 am
Hi There,
Oh yes, I now clearly see what you mean (Shoulda Looked a little Closer perhaps, Oops), I'd never seen one of these gizmos in action, and I didn't realise they are not a cutter as such. Another thought was using a Hole Saw but again I guess the CDs would be quite difficult to hold securely while making the cutout. Scope in the marketplace for a CD Modification Gizmo I think, as a quick glance at the many videos on the tube seem to indicate that CDs are an often used media for experimenters and experienced cutters alike. MMMmm??Te He :wink: :P :D
Fela Borbone
Post: # 41150Unread post Fela Borbone
Mon Mar 07, 2016 4:36 pm
Maybe this?....
Boydie
Post: # 41152Unread post Boydie
Mon Mar 07, 2016 6:36 pm
If the cd hole is cut out won't it work in CD players and loss the cd/record thing
yourbedhead
Post: # 42294Unread post yourbedhead
Tue May 03, 2016 7:33 pm
allex_rex
where did you get the round bar?
for recording:
piaptk
Post: # 42299Unread post piaptk
Tue May 03, 2016 11:10 pm
I have a bunch that I had custom made. They are $.25 each. They are nice, because they are slightly sloped on the side, so they sort of pop in and stay put more or less. email me at lathecuts-a-t-ya-hoo-dawt-cawm
fredbissnette
Post: # 45410Unread post fredbissnette
Wed Jan 04, 2017 6:25 pm
i have emailed ya
