testing Audax cutterhead?
dietrich10
Post: # 15246Unread post dietrich10
Tue Jun 07, 2011 12:32 pm
Trying to test this head. no clue what i am doing on this end
anyone?
cutting lacquers-vms70 system
TotalSonic
Post: # 15247Unread post TotalSonic
Tue Jun 07, 2011 12:43 pm
Quick and easy test is just to get a multimeter and check the resistance
(Ohms) from one input lead to the other input lead. I think these are supposed to be wired for 16ohms (but I could be wrong).
Best regards,
Steve Berson
JayDC
Post: # 15248Unread post JayDC
Tue Jun 07, 2011 1:22 pm
should be similar to a presto head, use a low power amp..
dietrich10
Post: # 15249Unread post dietrich10
Tue Jun 07, 2011 2:54 pm
thanks guys. easier than i thought 8)
petermontg
Post: # 15250Unread post petermontg
Tue Jun 07, 2011 4:53 pm
Should be wired for 8ohms 500watts read here recently gib can mod them to 50watts and drive the at +10db, just picked one up too.
Peter Montgomery
+353(0)894926271
Serif
Post: # 15251Unread post Serif
Tue Jun 07, 2011 10:56 pm
Markrob reminds us that the DC resistance which is what the multimeter reads when the head is not being fed a signal will be much lower than the head's rated AC impedance. So, single digit Ohmage is most likely if it's on the workbench?
-Styli Wigglen
