Building a Horseshoe Magnetic Mono Cutter Head (pics)
RecordLabelTroll
Post: # 25035Unread post RecordLabelTroll
Sun Apr 28, 2013 7:04 pm
Hey,
I'm not currently making one but for those of you who want to check this out!
http://philcoradio.com/phorum//showthread.php?tid=1017
Its a Horseshoe Magnetic Cartridge but I feel it'll also work in reverse to cut
RecordLabelTroll
Re: Building a Horseshoe Magnetic Mono Cutter Head (pics)
Post: # 25037Unread post RecordLabelTroll
Sun Apr 28, 2013 8:01 pm
You can also probably use the info and research to make something more of the modern stereo pro heads, now that you know the basics.
JayDC
Post: # 25045Unread post JayDC
Sun Apr 28, 2013 11:29 pm
i bet if the coil and spring are strong enough you could cut with this pick up, has a VERY similar design to old presto and RCA heads...
dubcutter89
Post: # 25051Unread post dubcutter89
Mon Apr 29, 2013 3:28 am
Yes, those old pickups can be used for recording. I have a book that suggests using a pick up if your budget is tight...
Principle is the same, but there some differences to real cutters. Stiffer springs, stronger coils...
But might be good for some lofi stuff.
