The state this lathe came into me was that it had a Capps system installed at one point, but it was removed and there was a simple motor controller board hooked up to a PC running a simple software. All of the original relay boxes were there, as well as a bunch of modifications. I decided to take it all down and start from scratch. I practically removed everything but the lead screw and the carriage. Every bearing is new, motor is serviced, etc.
You might notice the user panel is new..
It's for controlling Flo's Pitch13 system, and also the motor on/off & stylus heating circuits are there. A couple of relays driven by logic circuits, nothing fancy. The motor is controlled by a Siemens motor controller.
That head was recently serviced by Len Horowitz, the other one is going there soon. I think I want to hook up the non-checked head first.
The leadscrew motor mount
Pitch13 with the top open
I used the old terminal blocks for wiring the thing up. Now I have a cover on those, so it's an old photo.
That would be where I hid the Siemens controller.
And my mastering room as seen from the lathe.
What is missing from these pictures is my new LED microscope light controller from TDKK (http://www.tdkk.nl/products.html). It's a great little thing.
Anyway, things have been slow with the lathe since I'm pretty busy doing mastering work and I've been only doing this every now and then. It's good to have it wrapped up soon. In a few weeks I'm taking a little vacation and plan to do modulated test cuts then. Also I need to build a simple head protection card - the head is going to be on a relay, and the relay will be driven by a couple of inputs. The head will be disconnected if it's up, if the power goes out or in case of too much current.
