Presto K8 Lathe Arm
tapesandtubes
Presto K8 Lathe Arm
Post: # 40076Unread post tapesandtubes
Thu Jan 28, 2016 11:02 am
Does anyone know how to remove the lathe arm from a Presto K8?
Presto K8 | 6N
rsimms3
Re: Presto K8 Lathe Arm
Post: # 40077Unread post rsimms3
Thu Jan 28, 2016 11:06 am
I think you have to unscrew the knurled knob and then loosen the hex nut at the base.
tapesandtubes
Post: # 40096Unread post tapesandtubes
Fri Jan 29, 2016 1:24 am
Thanks, I got it figured out. You have to remove the hex screw that's on the knob and work that off (which was a pita) and the rest comes apart. Years of old grease sort of stuck everything together horribly...
Presto K8 | 6N
Gridlock
Post: # 40097Unread post Gridlock
Fri Jan 29, 2016 2:11 am
You can put a washer in there to raise the assembly in case you have a fancy tt mat. I took my mat off because my blanks were riding too high. I don't lean back too hard. We need a whole forum section for just the presto k series.
tapesandtubes
Post: # 40106Unread post tapesandtubes
Fri Jan 29, 2016 10:37 am
Yeah, that's not a bad idea. I think there's enough people out there restoring these...
Presto K8 | 6N
Jesus H Chrysler
Post: # 40155Unread post Jesus H Chrysler
Sun Jan 31, 2016 5:19 pm
loosen the allen head set screw on the cap and remove the cap. Then loosen the two on the gear arm. Then it should pull straight up. It may be a little rusty so you might have to work it back and forth as you pull, but that's all there is to it.
grooveguy
Post: # 40553Unread post grooveguy
Wed Feb 10, 2016 10:11 pm
That is a gorgeous K8; looks to be in pristine condition. Where on Earth did you find it? Has the advance ball, too. Wow! Is the rubber tire in good condition? What does one do if it isn't?
Bahndahn
Post: # 40556Unread post Bahndahn
Wed Feb 10, 2016 10:40 pm
grooveguy wrote:That is a gorgeous K8; looks to be in pristine condition. Where on Earth did you find it? Has the advance ball, too. Wow! Is the rubber tire in good condition? What does one do if it isn't?
If one is need of rubber roller repair, it is essential to visit the expert on rubber roller repairs. One must contact this fellow:
http://www.terrysrubberrollers.com/
