This is a RCA cutting lathe. The model plate has already faded. I need to identify the model to look around for manual and stuff..
It came with 2 grampian
More to follow about this
Stevie342000 wrote:I suspect that your model is single speed i.e. 78 rpm only it is probably an earlier model in the RCA 73 Range.
I found this which should help you: http://www.americanradiohistory.com/Archive-Catalogs/RCA/RCA-Broadcast-Equipment-1940.pdf
Does that mean you will change the feedscrew to make it microgroove compatible?pdmillar wrote:RCA 73-A owner here. This looks like it might be older than mine! How is your turntable coupled to the motor? Mine has this mechanism to the left of the platter. Normally has a cover on it, idlers shift up and down for 33/78. There seems to be very little information on these available compared to the Prestos.
I'm looking at converting mine to work at microgroove pitch, setting up to cut plastic with a Myshank diamond, and repositioning the overhead so it cuts on the center line of the disc rather than overhanging by 10mm or so (what's up with that? the resultant tracking error must have been considered negligible for 78 stuff)
i am interested! going to start the restoration pretty soon!grooveguy wrote:Looks very 73B-ish to me. The giveaway is the platter sunk into the top plate. The 73A rode quite a bit higher. Similar overhead with the friction-drive pitch selector on the side, but the 73B used a horizontal-format head instead of the traditional vertical horseshoe-magnet type. I'm not sure, and stand to be corrected, but it seems to me that the horizontal-format heads, which were hinged closer to the surface of the disc, tended to 'chatter,' or go into vertical oscillation more easily that the traditional Presto type of mounting. Another difference between the 73A and 73B, the spiraling crank is missing. I believe there was a separate motor for spiraling. Oliver Read's book covers the 73B fairly extensively. I could scan and post if anyone is interested.
