sand filled records
JHL
sand filled records
Post: # 50785Unread post JHL
Wed Jul 11, 2018 11:15 am
Hi Trolls!
havent seen this topic so i start a new one :D
just try to make sand filled / liquid filled records recently, here is my work,
it's not prefect yet,sand can flow but lots of sand still stick on the record,
glue is too hard to control and leave a mess on the inner record
anyone have experience can share with?
untitledthe
Re: sand filled records
Post: # 50793Unread post untitledthe
Thu Jul 12, 2018 1:12 pm
Great job, im sure there are people here who can get you a step further.
Good luck!
Post: # 50794Unread post tragwag
Thu Jul 12, 2018 6:18 pm
this looks so cool! I'm not sure of his public availability but I did lathe cuts for the artist Curtis Godino
who filled them with liquid for his band Worthless
here's the discogs entry: https://www.discogs.com/Worthless-Greener-Grass/release/6013649
JHL
Post: # 50795Unread post JHL
Thu Jul 12, 2018 10:41 pm
tragwag wrote:this looks so cool! I'm not sure of his public availability but I did lathe cuts for the artist Curtis Godino
Hi tragwag!your liquid filled record looks so good,i am wonder what kind of glue do you use ? how do you create the middle layer?
here is my way to do the sand filled record
1.prepare two 1mm transparent blank and cut
2.3d print two circle ring,thickness is 1mm too
3.use glue to stick circle rings on one blank and fill the sand in
4.stick another blank on it,done
3d print circle ring is too expensive :shock: those two rings cost me about 5USD,i guess have alternative way?
Gridlock
Post: # 50796Unread post Gridlock
Thu Jul 12, 2018 10:46 pm
Cut your sides first in case you mess up a cut and don't want to scrap the whole finished product
