my setup
- fredbissnette
my setup
ive had a few ppl on the board msg me about my setup
so i made a very quick vid
enjoi
https://www.youtube.com/watch?v=l2PU3cPf2d0&t=17s
enjoi
Re: my setup
Well done. I would have liked to see the overhead in more detail and heard the playback but still good.
- soeffingodly
Re: my setup
Dope!
That stereo head looks pretty sweet. Thank you for sharing.
- fredbissnette
Re: my setup
I have a mix up on soundcloud search nexus6ix the mix is called lathe cut dub mix check that for playback keep in mind I played it on numark pt 1 so on a regular deck the fidelity would be slightly higher.
- grooveguy
Re: my setup
Quite commendable results, Fred. I don't have a Soundcloud account, and they wanted me to get one, but if you just go to soundcloud.com/nexus6ix, there it is! I don't see or hear vacuum in your YouTube video, so I assume you're embossing. Would be interested to know: is stylus homebrew or bought, and if so from whom; what material you're embossing on; and the vertical angle of your stylus to the record surface. For the relatively small diameter you're recording at, the sound is remarkably bright.
- fredbissnette
Re: my setup
its one of jerrys tungsten from ebay i also use sapphire cones but not on that mix
my angle is pretty relaxed
i emboss on clear lexan and black makrolon, the mix was made on black makrolon
cheers
cheers
- grooveguy
Re: my setup
Well, it sounds quite respectable. Do you use a lubricant? A snapshot of the system in action would be helpful. Thanks!
- fredbissnette
Re: my setup
I use turtle wax
It works the same as any other lathe
Computer to amp to lathe
All processing done in reaper
- fredbissnette
- fredbissnette
Re: my setup
i cut this today
its clear lexan embossed with tungsten
https://www.dropbox.com/s/3xlwo99po8sdmzf/mt%20airy%20demo%20not%20for%20resale.wav?dl=0
pretty much the ballpark of what my cuts sound like
