Saxograph lathe
tape
Saxograph lathe
Post: # 55812Unread post tape
Mon Jun 01, 2020 2:58 pm
Anybody has some info on this "Saxograph" lathe ?
Was found in a garbagebin :-)
Soulbear
Re: Saxograph lathe
Post: # 55813Unread post Soulbear
Mon Jun 01, 2020 3:05 pm
Nice Find!! WOW!!!! :P :) :D The Clamp Looks very Poltz Freres-ish but does it have the Dual Motor?? Curious in Case it's a Re-Badged Poltz Freres?? MMMmmm??? :wink:
Soulbear
Re: Saxograph lathe
Post: # 55814Unread post Soulbear
Mon Jun 01, 2020 3:13 pm
Possibly German?? Erde = Earth or Ground in "die deutsche Sprache" The other terminals are similarly German Terms :wink:
tape
Re: Saxograph lathe
Post: # 55815Unread post tape
Mon Jun 01, 2020 3:18 pm
Yes that's the thing I do know - that it's german and made by the company rudolf reim, possibly in the 1940s
Google has very little on "saxograph"
Soulbear
Re: Saxograph lathe
Post: # 55816Unread post Soulbear
Mon Jun 01, 2020 3:28 pm
Check out this Mechanical Motor Speed Regulator It operates on a Centrifugal Spring Tensioner which controls an "Air Vane" within the Dual Motor. There could be a missing lever on this lathe of yours??? The Lever Graduation Plate Marks do look to be the same as on this Poltz Freres though :wink:
tape
Re: Saxograph lathe
Post: # 55818Unread post tape
Tue Jun 02, 2020 3:46 am
yes, looks a little bit diffrent on mine but says "dual motor"
tape
Re: Saxograph lathe
Post: # 55819Unread post tape
Tue Jun 02, 2020 3:47 am
also on my unit there has been a playback arm that is now missing
Soulbear
Re: Saxograph lathe
Post: # 55821Unread post Soulbear
Tue Jun 02, 2020 5:36 am
I'm also seeing some similarities with the Poltz Freres "Disc Clamp" on the Platter but can't quite tell from your Photo. Here's clearer Photos of the Clamp from a Poltz Freres. From what little I know about the Saxograph is that it was possibly a German "Recorder" used for recording commentary akin to the UK MSS "Midget" from around the same period?? http://www.orbem.co.uk/repwar/wr_midget.htm Nothing to stop you recording music on it though eh??!! Soulbear :wink: :wink: :P :) :D
tape
Re: Saxograph lathe
Post: # 55823Unread post tape
Tue Jun 02, 2020 3:21 pm
thanks!
It it exactly the same clamp
ok so maybe it was more or less the same machine. However I can not find any info when I google "Poltz Freres"
tape
Re: Saxograph lathe
Post: # 55825Unread post tape
Tue Jun 02, 2020 3:27 pm
btw: this is the only photo I have able to find of my unit on the web
Soulbear
Re: Saxograph lathe
Post: # 55828Unread post Soulbear
Tue Jun 02, 2020 4:08 pm
Have a look down in the reference section Poltz Freres Photos :wink: :wink:
Soulbear
Re: Saxograph lathe
Post: # 55839Unread post Soulbear
Thu Jun 04, 2020 12:46 pm
:oops: :oops: :oops: *****SIGHS**** :oops: :oops: :oops:
Ich komme immer wieder zurück, um mir das anzusehen. Ich finde es so eine sehr schöne Sache. Ich bin verliebt in Fräulein Saxograph Te He!! :wink: :wink: :P :) :D
