do you only have myshank stylus and souri blanks to use?
can you try myshank blanks? sounds like the materials + stylus aren't super compatible if all else is correct
Re: original RIAA curve with T560 (bypass souri's main unit)
Great all the tips here, i `ll take a moment to check vacuum details, and see if it`s time change anything.
I`ve read that post and feel great about the David 34 solution, and a lot of info of interest.
Now im getting to try all the things in the pitch motornoise (Bestseller hehe) says to find reason of the noise.
Also put rubbers below the hardware.
Filter is the original that comes with machine.
Thank you.
Thank you.
By way of closing my publication I would like to share with you the solutions we apply to our problem with the T560
1. The reason that made the stylus short-lived was a large amount of DC Offset (2 DCV) on one channel of the amplifier (Samson SERVO 600). It was repaired and it works fine now and we also have a backup one.
The hum that I had on the recordings was removed with the Behringer hum destroyer.
The friction noise was fixed by opening the grooves distance further and heating the discs to 45 degrees.
The noise that existed from the vacuum was fixed by changing the stylus for a Souri`s (a lot of distance between suction pipe and stylus)
After closing this post I will open another one to get help on the size of the stylus of my shank and the little space I have left between the stylus and the disc.
Thanks to all who offered solutions and words of encouragement.
Gracias amigos.
Gracias amigos.
Re: orignal RIAA curve with T560 (bypass souri's main unit)
Hi. A but late to the conversation but hyaenamx I listened to your sound clip and I have the same high pitched noise. My tube is very close to the stylus so that could be the problem. I will try like you without suction to see if it's better
Thank you
Nik
Thank you
Nik
Nik Clifford
Pearl Home Records
Pearl Home Records
