frizzy curly swarf - more weight
Hey There
I am using a MSS vintage mono lathe with myshank diamond and blanks.
Cutting has been going great, but recently swarf has gone frizzy and curly and not going up the tube!
I am already pressing down with 16grams. so dont want to go too high.
The cuts are still sounding ok if i sweep away the swarf (and get in a big tangles mess).
Oh an i am heating the blanks up to 26 degrees C and using a little stylus heat
Anyone got any ideas?
Regards
Nik
Regards
Nik
Nik Clifford
Pearl Home Records
Pearl Home Records
Re: frizzy curly swarf - more weight
Are you using any anti-static treatment? It could be humidity-related also. Not too sure about London, but up here we've just gone from a heatwave to unseasonably cool - high humidity to low - so more static. Do you have a microscope? Rather than relying on weight are you able to measure the width/depth of the grooves? Have you changed the angle at all?
Hi Handcut, Thank you very much the reply.
Yes I am using turtle wax spray for anti-static. The humidity is around 47% the moment, which it good. Though its been hot here (for London) and humid at the same time. sometimes it gets down to 27%.
I do have a normal microscope but not attached to the lathe as cant see how i would get one to see under the MSS cutterhead. But i can look at blanks once they are cut. I could measure the groove width i guess, but how would you measure the groove depth?. The cutting angle is roughly the same but i'll take a closer look.
i will get a photo of the cutterhead
Best wishes
Nik
Best wishes
Nik
Nik Clifford
Pearl Home Records
Pearl Home Records
..... and here is photos to show the head
http://www.nikclifford.co.uk/photos/20210611_105600.jpg
http://www.nikclifford.co.uk/photos/cutterhead_smaller.jpg
Nik Clifford
Pearl Home Records
Pearl Home Records
The microscope goes on the side opposite the head.
Groove depth is always just under half groove width if the cutter stylus is in even reasonable condition, as the stylus has a 90 degree tip (With a typically 1 micron rounded point, hence the just under).
I had a likewise problem but with a VR.
Could only solve it by increasing the weight of the head. Had torque issues as a result and needed to upgrade to a better table with more torque. But this solved the issues with swarf completely. Now at about 21 grams I think.
Thanks that really good to know. What is a goo groove width?
Nik Clifford
Pearl Home Records
Pearl Home Records
Hello again
my groove width is roughly 50um. That seems like its in the range of ok. Yes?
Nik
Nik
Nik Clifford
Pearl Home Records
Pearl Home Records
