Turntable for 14" lacquers/mothers
Sorry if there is already a topic on this, I couldn't seem to find one.
I am looking for a good turntable for listening tests on 14" lacquers and mothers. Preferably one which can switch off the automatic rotations so I can do small turns by hand to locate specific areas in the grooves.
If there are any particular models which work well for this task I would be grateful to be shown which ones.
Re: Turntable for 14" lacquers/mothers
I use EMT but you can play 14” lacquers on 1210’s too
- leemichael
No i mean 1210…fits perfectly fine if you leave original rubber and an extra slipmat. Played 100s on it. Try it.leemichael wrote: ↑Fri Oct 08, 2021 2:27 pmDo you mean SP10? 14” won’t fit on a 1210 unless you drop the strobe tower and relocate the tonearm.
Thanks for the quick replies.
We have a 1210 but it seemed too tight I will try an extra mat.
I will also check out the EMT.
Does the sp10 work well for this?
- martinstamper
Cheap option is the Audio Technica ATLP5 - it will fit a 14" with no modification at all. If you shop around the vintage hifi world there are hundreds of transcription turntables that will accommodate a 14" disc without any modification too, it just might involve traipsing around a few hi-fi dealers to try them out.
Great Martin thanks for this
