Plotter / Cutter for labels and sleeves
PMST
Post: # 59628Unread post PMST
Sun Oct 17, 2021 5:42 am
I am looking for a plotter to be able to print and cut my own labels and 7" and 10" sleeves. I was wondering if anyone with experience in printing has any advice?
In the 'budget' area i've seen the Silhouette Cameo 4, would this be suitable? If not, do you have any links to something else i should be considering? Based in Europe.
David34
Re: Plotter / Cutter for labels and sleeves
Post: # 59638Unread post David34
Tue Oct 19, 2021 5:12 am
My Toshiba copy centre prints A3, and 7" fits inside an A3 Paper.
I am very interested in printing the other sizes too, so I hope someone can answer!!
David34
Post: # 59639Unread post David34
Tue Oct 19, 2021 5:15 am
Correct me if I am wrong, but doesn't that only cut vinyl rolls?
PMST
Post: # 59649Unread post PMST
Wed Oct 20, 2021 5:36 am
The cameo can cut loads of different materials, even fabric.I know one person who uses it and gets good results and with the Cameo 4 can make sleeves easy enough, but just wanted to see if anyone uses one, or something similar
12bitcuts
Post: # 59652Unread post 12bitcuts
Wed Oct 20, 2021 4:43 pm
Has anybody tried using a Cricut "Maker" (www.cricut.com) to create some DIY record sleeves/packaging?
Looks like it is potentially up to the task for small projects.
ABON
Post: # 59654Unread post ABON
Wed Oct 20, 2021 11:00 pm
cricut software is BASIC .. silhouettes software is brilliant .. i recommend cameo 3 or 4 or even a curio ... curio is good becuase you can fit 5mm items in it (so gatefold sleeves) it wont cut 5mm though
Post: # 59660Unread post tragwag
Fri Oct 22, 2021 11:06 am
great idea! I've just used a combo of manual paper cutter and xacto blade to do my glue pocket jackets
jjwharris
Post: # 59693Unread post jjwharris
Wed Nov 03, 2021 7:47 am
I'm using a cameo 4, it works well when it works. Occasionally it'll start mis-registering and I'll have to restart the cameo, the computer or make a weird face and it'll start working again
I'm reluctant to use it to cut sleeves as I worry about the adhesive from the cutting mat transfering to the sleeve and then the record. I'm sure an inner sleeve would solve it.
12bitcuts
Post: # 59742Unread post 12bitcuts
Fri Nov 12, 2021 9:56 pm
I hear ya, it (Cricut) is also subscription based & locked to there software only (I think) which I don't necessarily like.
In any case I haven't used the Cricut extensively I but did a small batch of full color vinyl sticker a while back and they came out great, this was over a year ago and I have not used my Cricut since.
Now I am getting active in record cutting again and after ordering some blank 7" labels recently, it looks like something a Cricut could easily cut, just need to find right material.
I'll try to give it a spin this month, just got to get a suitable template made in Illustrator.
jjwharris
Post: # 59835Unread post jjwharris
Sat Dec 04, 2021 9:57 pm
Just dropping in again to say how annoying the Silhouette Cameo 4 is.
I think it took me about 5 minutes to get one sheet of labels registering - maybe it's cause I keep re-tacking the matt...
descent
Post: # 59866Unread post descent
Wed Dec 15, 2021 6:57 am
you can do everything with this one: https://www.ebay.com/itm/115130886805
