T560 vacuum lid replacement
David34
Post: # 57105Unread post David34
Sun Nov 01, 2020 1:47 am
Hello I’ve had to replace the lid after 7 years of use.
Looked around everywhere and found the following, which looks great upgrade in wood.
Kmart $4!
Hope this helps someone on here out.. you’ve all helped so much!
Vinylfan
Re: T560 vacuum lid replacement
Post: # 57106Unread post Vinylfan
Sun Nov 01, 2020 3:15 am
have a look here:
https://gies.de/katalog/giesline/vorratsdose-rund/ (site in German only)
This is the original lid that came with the VR. Costs around EUR 4.-
Haven‘t found this product in a (online-)shop. Made a call to a very friendly person from the „Verkauf“ team and she was so kind to arrange the shippment of 3 „Vorratsdose Rund“.
Hope that helps.
RedSpadeRobyn
Post: # 57119Unread post RedSpadeRobyn
Mon Nov 02, 2020 2:40 pm
I had to replace mine too, but I just asked Souri to send me a new one. And he did.
That wood one looks sharp though!
Post: # 57129Unread post tragwag
Tue Nov 03, 2020 12:55 pm
thank you for this! I'm keeping track of as much of the second hand replacement stuff for the VR that I can,
as a second hand user with two VRs my numbers gonna come up with all of these parts some time
leofam05
Post: # 60553Unread post leofam05
Thu Apr 07, 2022 4:54 pm
Hey does anyone know where i can get a LID replacement in EUROPE ? Is kind of urgent
mine can't be glued anymore. :(
Tremdall
Post: # 60561Unread post Tremdall
Fri Apr 08, 2022 4:26 am
Did you try buying from Souri?
leofam05
Post: # 60566Unread post leofam05
Fri Apr 08, 2022 1:30 pm
i need an alternative.
Tremdall
Post: # 60567Unread post Tremdall
Fri Apr 08, 2022 1:58 pm
PLD
Post: # 60573Unread post PLD
Fri Apr 08, 2022 6:56 pm
I just got a couple of bits of scrap plywood, drunkenly cut them vaguely circular with a jigsaw, screwed them together with some thin rubber inbetween to seal against the rim of the jar and drilled a couple of holes in. It looks absolutely awful but works fine, and there's no way it's going to break again (well, until the plastic jar itself gives up, that is). If you can't do this yourself you're likely to know someone who can, and probably better than me.
leofam05
Post: # 60576Unread post leofam05
Sat Apr 09, 2022 10:17 am
Thank you mate
