Silvertone cutter head
Spectrum1
Post: # 63779Unread post Spectrum1
Fri Dec 01, 2023 7:36 am
Hi pleasant day to all just as we embark upon such festive season of Xmas
I must first let you know I have got very little knowledge about lathe cutting and any advice will be humbly accepted.
I have a silvertone 3751 1941 model The amplifier works. But would not get the levels for today standard so I am using a separate amp, I am just using the platter but the head was a crystal head and I would like to replace it with a magnetic head ? Any ideas? Which other head could work on this unit as it has limited space due the configuration at the time.
Any help is appreciated
Kind Regards
Pablo
Spectrum1
Re: Tube amplifier
Post: # 65726Unread post Spectrum1
Sun Sep 15, 2024 11:40 am
Hi good day can anyone help with this question I have a tube amp and I would like to use the plat voltage from the EL34 to drive the crystal head. But the problem is that it’s a push pull … Not a single ended. Transformer …. Can someone say if it is possible to. Use a push pull Tho do the job Any help is Appreciated kind regards.
Pablo
