Cutterhead Stylus Screw Buzz (RCA MI-4889)
sameal
Re: Cutterhead Stylus Screw Buzz (RCA MI-4889)
Post: # 65307Unread post sameal
Sun Jul 07, 2024 10:11 am
piaptk wrote:
Sun Jul 07, 2024 9:01 am
@Sameal what magnet did you put inside the webster? Ive got a stack of those things and none of them are even marginally loud enough to use.
I used some neodymium stock from evilbay and then closed the magnetic gap with some cut down "I" sections from a transformer I tore apart. I also replaced the rubber dampening with some left over rubber scraps I had.
(I stole both of these ideas from jesus agnews rebuild docs and soulbear conversations.)
https://www.ebay.com/itm/283858982354?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=HYYzyGS2Skq&sssrc=4429486&ssuid=0QoAHskVSpi&var=&widget_ver=artemis&media=COPY
I deleted all my video on it off my phone, but if you look at the very end of this refurb video, you'll see the playback
https://youtu.be/__CUy5jyOpc?si=B6k5Wq7Z-TCEahJg
The video shows how weak the magnet from the webster is. (Ignore the gauss meter, I think it isn't very accurate and didn't end up using it.)
I'm running from the d.a.w. to an I.R.I.A.A. board into a mcgohan tube p.a. head. I think thats it. I tried embossing a bass heavy track and did not have nearly as good results. I'd like to try a new coil someday.
It's still a webster, but it brought it back to useable condition I think. Or at least destroyable condition!
