Cutting cds
Post: # 6867Unread post piaptk
Fri Dec 04, 2009 2:55 pm
What do you guys use for center spacers? I've tried everyone size washer and nothing fits both the center hole and spindle just right. Peter king sent me a bunch bolts that fit pretty well, but they are pretty ghetto to include with the records I cut.
Record Hole Sizes
Post: # 6869Unread post mossboss
Fri Dec 04, 2009 5:03 pm
There is a thread on this have a look at it It may give you some ideas
Are your records Kinked like doughnut holes? If so Andyb can sell/give you his punchings from his 45
Idea?
"The Vinyl Truth"
tape
Post: # 6874Unread post tape
Sat Dec 05, 2009 4:36 am
markrob wrote:Hi,
Maybe its some sort of resonance effect. Perhaps there is a slight difference in the material between the two discs and the increase in sliding friction and or stiction is exciting a spring mass resonance present in the stylus cantilever. I could envision the stylus transitioning from embossing to cutting in an oscillating manner.
I wonder if either stiffening or adding damping material (e.g. rubber) to the embossing stylus would kill this? What would happen if you were to apply a thin coat of lubircant (say silicone spray) to the surface?
Just some random thoughts.
Thank you very much for the good suggestions. Actually I cleaned the disc with vinyl cleaning spray and a cloth, but seems strange that it should make such a big difference.
The head is damped with thick 'airy plastic' don't know the english word for it-) so it should be damped ok.
Again, with the discs being identical, it seems unlikely that they should have diferent surface properties or thickness - they are from Japan:-)
For making a center hole I use thick cardboard with a punched hole and a label sticker - this works fine, but it hard to punch perfect centered.
