Diamond Stylus Available now
d
Post: # 13065Unread post d
Wed Mar 02, 2011 3:12 pm
Hey Andy,
thanks for a vid and for information. Always nice to see the process :)
What material have you tried instead of lexan?
JayDC
Post: # 13067Unread post JayDC
Wed Mar 02, 2011 3:51 pm
andybee wrote:yes, correct no facets -> hard materials, plastic, copper.
Whoa, I can cut on copper with these? There is a bunch of flat copper in the basement here, coz my great uncle work for the metal union..
cymbalism
Post: # 13068Unread post cymbalism
Wed Mar 02, 2011 4:31 pm
I've cut a few 7"s and LPs so far with brilliant results. I don't understand why people are having chip issues, mine comes off just fine into the suction tube. Steven is offering a great product to people, don't let the lack of reply steer you wrong, his diamonds are the real deal and actually work!
all the best!
- tommie 'plan 9' emmi
andybee
Post: # 13074Unread post andybee
Thu Mar 03, 2011 2:46 am
yes, copper can be cutted, but must be soft copper and you need
a DMM Lathe to do this.
copper chip comes off very hard, you need a special suction for this,
copper blanks must be complete flat on the turntable and must have
a perfect, shiny surface...
be careful! :) stylus can be dead very soon...
JayDC
Post: # 13086Unread post JayDC
Thu Mar 03, 2011 11:06 am
What makes a DMM head more able to cut copper over normal heads?
fraggle
Post: # 13091Unread post fraggle
Thu Mar 03, 2011 4:38 pm
Just out of interest why do you want to cut copper?
JayDC
Post: # 13092Unread post JayDC
Thu Mar 03, 2011 5:43 pm
The fact that i have some to cut...
Post: # 13096Unread post piaptk
Thu Mar 03, 2011 8:17 pm
fraggle wrote:Just out of interest why do you want to cut copper?
A true METAL record. harharhar.... 8)
andybee
Post: # 13116Unread post andybee
Fri Mar 04, 2011 10:58 am
the head must be strong, but the head is not the problem,
the problem is the chip, read my postings.
and, you need a special, soft copper for cutting, some people
did cuts into electronic blanks.. but this is an experiment
Post: # 13129Unread post mossboss
Sat Mar 05, 2011 3:38 am
Electronic Blanks from German, translation = Printed Circuit Board in English
or Copper Clad board
"The Vinyl Truth"
JayDC
Post: # 13260Unread post JayDC
Wed Mar 09, 2011 4:27 pm
stupid white sapphire, tricking me.. :(
JayDC
Post: # 13261Unread post JayDC
Wed Mar 09, 2011 4:28 pm
SHANK!!! what ur turn around time if I provide you with the long shank (462)? I thought I had a diamond, turns out to be a white sapphire.. I need a diamond asap, DEMF is fast approaching..
aaaaackkkkkuuughhhghghghghhghhg!!!!! MF!
Post: # 13305Unread post piaptk
Fri Mar 11, 2011 1:35 pm
JayDC wrote:stupid white sapphire, tricking me.. :(
Did you buy it on ebay? Every sapphire that pops up on there is listed as a diamond...
JayDC
Post: # 13306Unread post JayDC
Fri Mar 11, 2011 2:07 pm
no, it came with my lathe when I bought it.. they never told me it was a diamond, I just assumed because of its coloring.. I just didn't know that sapphires could come in white.. I'm not a jeweler..
Simon
Post: # 13311Unread post Simon
Sat Mar 12, 2011 5:43 pm
Yes they can
Happy to learn something new.
JayDC
Post: # 13453Unread post JayDC
Thu Mar 17, 2011 4:45 pm
I think I have made a good decision, and I'm going to stick with acetates for now.. I feel you trade sound quality for durability with the poly, even on a calibrated and proper setup..
For DJ's that scratch (battle DJ's) this stuff is perfect, you can make some great one off battle records with these for sure.. but for what I'm doing DJ wise I need the better quality sound..
I recently covered my lathe in dyamat extreme, and I'm surprised at the results.. I cut down the motor hum, and I have seemed to have improved my cutting head..
I basically wrapped the head in this stuff, and now it sounds like a dream. I covered the top of the platter, and 12" circle under the platter (to give room for the idlers). I plan on covering the overhead parts as well.. Looks like shit I have to say, but the sound improvement is worth the poor looks..
Post: # 13462Unread post piaptk
Fri Mar 18, 2011 1:38 am
How noisy was your motor to begin with?
I've got a motor that is LOUD and you can feel the vibration on the plinith. It's in the middle of being worked on by Kris, so I haven't cut anything with it, but I'm wondering if the Dynamat would make it usable, as I don't think it will sound very good with the motor the way it is. Would be worth the $40 of Dynamat if it will reduce the rumble I'm sure will be present without it, but I don't want to throw that $40 at it, unless I know it will work.
JayDC
Post: # 13463Unread post JayDC
Fri Mar 18, 2011 1:57 am
It dampened my head and platter pretty well (it doesn't ring anymore).. There is an audible difference between before and after. I found a 18" x 32" piece on ebay for about 20 bucks. There is still a slight 60hz hum present in the silent groove, but as soon as the music hits, it more clear, and less distorted at high levels (I cut very bass heavy music).
I'm really starting to wonder if the hum is from the electricity running through the body of the thing. Maybe it's time to hard wire everything and stop using the body as neutral. Then ground the motor to earth (3 prong). So that the only electricity touching the head is from the amp.
TBH: I never heard another presto, so I have nothing to compare it to.
Post: # 13465Unread post opcode66
Fri Mar 18, 2011 3:52 am
JayDC
Post: # 13480Unread post JayDC
Fri Mar 18, 2011 12:31 pm
I agree. The presto has no ground at all, and all grounding lead directly to the chassis. The only way I can see of removing it would be to hard wire the microscope, and stylus heater (use 2 wires, not one). I can then ground the motor using a grounded power cord. I feed my amp using an optical digital connection and there is no hum present in the amp, if i listen using head phones.
