stamper playback system
Re: stamper playback system
Hey guys, first post
Jim
Jim
Ok, like I thought. Standard turntable. Tonearm mounted in standard location. Tonearm rest in standard location. Tonearm can swing out to accommodate the reversed direction of playback. Tonearm is straight. Headshell is crooked the opposite way than normal. Something like a 45 adapter for the center hole.
It is actually quite difficult to play a stamper even with this turntable. When you drop the needle for lack of a better word, it almost always lands in the land between the grooves. Which is odd sounding since the right and left channel are one revolution out of synch. You then need to gently tap it toward the center until you land on a groove.
One cool feature, the turntable has 2 magnet rings on the surface, to hold the stamper flat.
Jim
Jim
- Aussie0zborn
Thanks for the pic Jim and welcome to the Forum.
- Steve E.
- Site Admin
Re:
Wyndham Hodgson at Expert did make such styli, indeed, for awhile. He told me so. Sounds like he doesn't right now.emorritt wrote:Does Wyndam Hodgson at Expert in the UK make these? Just a thought...
I can have them made two ways. One stone with a notch. Or, you can grind two tips, bond them togeter and set them onto the metal part of a standard playback stylus.
pretty sure that dubplates and mastering in Berlin has such a device
- greenvinylrecords
have a look here at the Youtube movie, how it can be done on a regular turntable.
https://www.youtube.com/watch?v=WoWAptLW2b0
You can order them at:
https://greenvinylrecords.com/index.php/products/
Different stylii are available for 33/45 and 78 rpm.
