scully banding unit schematics
sameal
Post: # 65501Unread post sameal
Thu Aug 08, 2024 7:30 am
Anybody have schems or info on it? I got it as kind of a curiosity and to play with it, but i think i could get the timers to work for spiral.
I'm using a delay relay now and the issue with most of them is I only 1sec or 10seconds. Id like a little bit more useful range then that.
emorritt
Re: scully banding unit schematics
Post: # 65502Unread post emorritt
Thu Aug 08, 2024 8:12 am
I might; let me check the docs I have for my Scully equipment when I get home from work today.
sameal
Post: # 65503Unread post sameal
Thu Aug 08, 2024 8:45 am
Awesome! That'd help tremendously
sameal
Post: # 65622Unread post sameal
Sat Aug 31, 2024 3:15 pm
Well. If anybody has ideas on the connectors, id like to hear them.
I think the 10 pin goes to the button panel, but i couldn't get a closure to happen to trigger the timers. So i could be wrong. I have no idea on the 4 pin and 2 position barrier strip
flozki
Post: # 65624Unread post flozki
Sat Aug 31, 2024 5:15 pm
Imagenot sure if its this one.i have all the schematics for units nr. 560 upwards. but maybe your box is from an older model.need a little more infos on the connectors.
flozki
Post: # 65625Unread post flozki
Sat Aug 31, 2024 5:30 pm
on another one it says :"to banding unit 10PRONG male"
there is somewhere more schematics..
sameal
Post: # 65626Unread post sameal
Sat Aug 31, 2024 6:27 pm
Hey flo!
Here's some better pictures.
I was able to activate the coil for the wafer like switch in the center of the unit with a 24vdc power supply, and those wires go back to the ten pin military connector. The other coil in the center resets the setting on the wafer switch. I couldn't activate that one, the wire colors didn't match anything at the 10 pin, so i didn't send 24vdc to the other pins available.
The 4 pin amphenol had about 30vdc and 12vdc at each set of pins.
My hunch is both the 4 pin amphenol (power?) And the ten pin military (button contacts?) Went to the the scully button panel.
sameal
Post: # 65628Unread post sameal
Sat Aug 31, 2024 9:32 pm
Well, in larry bodens book it says the 4 pin goes to the photocell and exciter lamp. The ten pin goes to the sequence panel. No mention of the two position barrier strip. No schem either. :(
