Isolating vacuum unit.
concretecowboy71
Post: # 8393Unread post concretecowboy71
Wed Mar 31, 2010 12:56 am
Hey everybody. Here is another question for you. Is it and has it been in the past, common for the vacuum unit of a professional lathe to be moved out of the room to lower the noise in the room?
I understand the concept of a machine room but even the Neumann manual says to just put the unit under the frame of the machine.
I am interested also if increasing the length of the main vacuum hose would have detrimental effect on chip pick-up.
Right now I am having good luck (knock on wood) with my chip removal and don't want to screw up a good thing.
As always, thanks for the insight.
Post: # 8396Unread post Aussie0zborn
Wed Mar 31, 2010 3:21 am
You should get the vacumm pump out of your cutting room if it bothers you. You probably dont need this noise.
When the supplied vacuum pump on the VMS70 broke down, we used a vaccum cleaner with a swimming pool vacuum hose attached to extend the length The vacuum cleaner was in the other room and being a 240 volt country it was ofcourse a 240volt vacuum cleaner. I think we ran it off a 110volt transformer to reduce the suction. Chip removal was never a problem but you will find out in less than a minute if it is.
My earlier cutting lathes (AM32B and VMS62) were all set-up with a vacumm cleaner too, because that's how they came. The VMS70 worked like this for years (well, until the mainstream demand for vinyl died). The simple answer might be to "suck it and see".
So how is your cutting coming along then?
andybee
Post: # 8399Unread post andybee
Wed Mar 31, 2010 5:46 am
I use a air pump for home fish tank (aquarium),
but in reverse direction :)
low noise, they are on ebay....
concretecowboy71
Post: # 8403Unread post concretecowboy71
Wed Mar 31, 2010 10:27 am
Thanks guys. Very interesting. I am using swimming pool hose now but the length is only about 4 feet.
The set up is coming along slow but sure. My platter is level. I have been making cables and today I am wiring in my VU meters.
When I picked up the machine, the circuit breakers started acting up and Albert kept them and worked on them. Today or tomorrow we are going to get them installed and see what happens.
I have been cutting un-modulated grooves and following the manual guidelines. When it is all set up, I will post some pictures.
Post: # 8405Unread post piaptk
Wed Mar 31, 2010 1:18 pm
andybee wrote:I use a air pump for home fish tank (aquarium),
That's great! can you send me a picture of the one you have set up? I'm using a little hand vac with hose attachement, but it is SOOO damn loud. I tried putting it in a box, but it overheats every 5 minutes.
Internet
Post: # 8406Unread post Internet
Wed Mar 31, 2010 1:32 pm
I do it too :)
low noise and very effective
Post: # 8408Unread post markrob
Wed Mar 31, 2010 1:55 pm
I did a similar thing with a hand vac. I used a simple light dimmer to lower the speed of the vac. This will work with a universal motor. There is some hysterisis when using a cheap lamp dimmer as a motor speed control. You have to start at full speed and lower the speed from there. If you try to restart the motor at the last setting, it won't start.
The aquarium pump sounds like a great idea. I'll have to give that a try.
flozki
Post: # 8410Unread post flozki
Wed Mar 31, 2010 3:06 pm
neumann used for the vms80
2x fishtankpump in push pull configuration and quite soundproof case.
absolutely low noise....
but i dont remember the model they used...
f.
drdub
Post: # 8418Unread post drdub
Thu Apr 01, 2010 1:07 pm
the fishtank pumps work good with laquers, but we had troubles sucking in pvc chip. for some reason chip clogged up in the hose...
*** www.drdub.com ***
dietrich10
Post: # 8419Unread post dietrich10
Thu Apr 01, 2010 1:12 pm
on this topic still-
replacement hose from head suspension down to chip jar of vms?
mine giving issues
cutting lacquers-vms70 system
drdub
Post: # 8420Unread post drdub
Thu Apr 01, 2010 1:16 pm
we use a latex hose. if i am in a good mood i put some talkuum pewder in it ...
flozki
Post: # 8421Unread post flozki
Thu Apr 01, 2010 6:01 pm
[quote]the fishtank pumps work good with laquers, but we had troubles sucking in pvc chip. for some reason chip clogged up in the hose..[/quote]
you need more of the "white powder". and the chip sucks like hell..hehe....
i had this troubles with vms80... sometimes it depends on the tube material. silicone tube is good for laquer...for pvc sometimes not....
we found a black tube from festo... and the white powder then all was okay...
so i wish
hard eggs and soft chip
f.
andybee
Post: # 8427Unread post andybee
Fri Apr 02, 2010 9:27 am
muaaah,
I use the WISA/yusanaga LP-40A pump:
http://cgi.ebay.de/WISA-Yasunaga-Linearmagnetpumpe-LP40a-Enddruck-4200l-h_W0QQitemZ270282340025QQcmdZViewItemQQptZde_haus_garten_tierbedarf_fische?hash=item3eee1536b9
but be careful, there are some china clones available,
maybe they use another (louder) technologie...
maybe it doesn´t work that good with pvc, because the diameter
of hose is bigger = slower air flow.
there must be a difference between a 1500Watts cleaner and
a 100Watt Pump :)
andybee
Post: # 8428Unread post andybee
Fri Apr 02, 2010 9:31 am
this is the one, used in neumann 80 lathes:
http://cgi.ebay.de/Profi-Aquarium-Beluefter-Teichbeluefter-von-Wisa_W0QQitemZ290418993937QQcmdZViewItemQQptZde_haus_garten_tierbedarf_fische?hash=item439e522b11
two of them, like flo wrote,
I think it is a WISA 1000 Model, a bit old.... :)
Steve E.
Site Admin
Post: # 8479Unread post Steve E.
Fri Apr 09, 2010 5:10 pm
it's an awesome day for information around here! :D
punkrock
Re: Isolating vacuum unit.
Post: # 34751Unread post punkrock
Mon Apr 27, 2015 5:10 am
Been using a Vinylrecorder for 3 years now. This last year I've been cutting at least 10 times as much as the previous years. I bought Souri's vacuum when I bought the cutter and set it in a different room, but this year I think it's starting to get old. It kinda "smells", it looks perfect, it's not burnt, but it starts to smell different... Also, I placed it in a different room so it's not noisy in the cutting room, but it's noisy in that side of the house, for hours!
I imagine it's time to start thinking about replacing it and improving the system if posible. Souri has a vacuum pump for sale, but it costs 465 Euros...
Investigating a bit I discovered this old thread, anyone has updated news? Should I go for the fish tank pump? Any recommendations?
drdub
Post: # 34752Unread post drdub
Mon Apr 27, 2015 7:29 am
we buy a new vacuum every 2 years or so.
industrial type "kärcher" models.
they don't last to long. expect them to fail...
punkrock
Re:
Post: # 34756Unread post punkrock
Mon Apr 27, 2015 11:32 am
drdub wrote:the fishtank pumps work good with laquers, but we had troubles sucking in pvc chip. for some reason chip clogged up in the hose...
drdub wrote:we buy a new vacuum every 2 years or so.
So I guess you abandoned the fish tank pump idea for the vinylrecorder. It didn't work out well? No one is using the vacuum pump or the fish tank pump anymore? It sounded as a good idea...
duomo
Post: # 34759Unread post duomo
Mon Apr 27, 2015 2:17 pm
I'm cutting with a fishtank pump for over 10 years now, without any trouble, bouth laquer and pvc. just put some baby pouder in hose.
Moritz
www.duophonic.de
vinylcutting / mastercutting/ pressing
drdub
Post: # 34766Unread post drdub
Tue Apr 28, 2015 3:11 am
we have both. the pump is our backup. then we forget about it and cut with pump...
like moritz says :works both
since we have an isolated room for vacuum, air compressor, noisy power amps, we do not hear theses things anymore.
