master laqure vinylium dubcutter
rocness
Post: # 11465Unread post rocness
Fri Nov 19, 2010 12:56 pm
graph wrote:just to clarify;
when adapting Vinylrecorder to use feedback cutterhead & sapphire/appropriate stylus, its then possible to cut masters?
cheers.
Newbie Alert !
So to cut a 12in master lacquer for a 10in vinyl record with Vinylium Dub cutter
I should have every thing I need but have to use a sapphire stylus. If so
where can I get a sapphire stylus (price).
Thanks
Post: # 11467Unread post opcode66
Fri Nov 19, 2010 4:41 pm
apollomasters.com
rocness
Post: # 11468Unread post rocness
Fri Nov 19, 2010 7:06 pm
opcode66 wrote:apollomasters.com
Thanks
So I guess all I have to do is put the sapphire on The Vinylium Dub cuttert
then I should be good to go . So once I have my master lacquer done where
do I send it to be mass produced.
Thanks
Post: # 11471Unread post mossboss
Sat Nov 20, 2010 12:50 am
To your local friendly Record Pressing Plant mate
Where are you located?
There is a list of pressing plants here under Plating and Pressing look in there I am sure you will find one close to you OK?
cheers
rocness
Post: # 11479Unread post rocness
Sat Nov 20, 2010 10:41 am
mossboss wrote:To your local friendly Record Pressing Plant mate
cheers
I'm in NJ ,I'll have a look over in plating and pressing .
Thanks my friend.
rocness
Post: # 11481Unread post rocness
Sat Nov 20, 2010 11:18 am
What is plating ?
petermontg
Post: # 11482Unread post petermontg
Sat Nov 20, 2010 1:01 pm
theres loads of videos here, just hit search, and search for plating or galvanics
or hit up youtube
there is a whole section for plating and pressing here have a look through it
Peter Montgomery
+353(0)894926271
rocness
Post: # 11489Unread post rocness
Sat Nov 20, 2010 10:00 pm
Thanks
