the source materialsubkontrabob wrote:The waveform of what? A recording of your cut, or the source material?carter wrote: when i looked at the waveform in protools, it appeared highly compressed.
thanks for the recommendation on the plugin - didn't know that site.
just using the filters built-in the VC200, which put everything below 700hz in mono and apparently has some high end/low end rolloff that i'm not sure of.dietrich10 wrote:are you using high pass and low pass filters as well ??
