Where does the oil go for the presto 6n motor
Jccc
Post: # 11662Unread post Jccc
Wed Dec 01, 2010 4:41 pm
i was wondering if there is way to oil up the presto 6n motor that powers the turntable.
Just recently for some reason when im cutting on 33 1/3 the turntable starts to spin super slow.
Also sometimes when i turn the motor on to 33 1/3 the motor does not start. It works perfectly some times on 78.
Could it be that i new rubber rollers for it?
cymbalism
Post: # 11663Unread post cymbalism
Wed Dec 01, 2010 5:25 pm
There are two pots, one at the top on the right side of the 78 puck, the other is on the bottom and has a silver or gold pipe running to it
all the best!
- tommie 'plan 9' emmi
piaptk
Post: # 11666Unread post piaptk
Wed Dec 01, 2010 7:05 pm
Take the platter off and see if the capstan starts spinning when you engage the 33. You might just need to adjust the screw back a litle so that the idler gets pushed in to the capstan a little harder. Also make sure your switch is still aligned right... Mine got off it's axis a little and I hve to use a loop of wire to start it...
cymbalism
Post: # 11667Unread post cymbalism
Wed Dec 01, 2010 7:08 pm
Also check the connections on your power switch. My second 6n wouldn't spin on 78, I replaced the switch now all is well
all the best!
Jccc
Post: # 11668Unread post Jccc
Wed Dec 01, 2010 7:37 pm
Thank you guys for help. I got it oiled up and running.
The power switch was loose so i tightened it up and its all good now.
cymbalism
Post: # 11670Unread post cymbalism
Wed Dec 01, 2010 11:16 pm
No prob :)
all the best!
