Excuse me sir, didn't know you are an expert on my experiences.It seems you haven't understood the reasons why "high speed cutting", as described by you, makes no sense.
1 and 3 are not a major concern... The physical size of cutting and reproducing stylii dictates the upper frequency limit is not even true, ask stan ricker..Lets review some basic facts:
1. The wavelength of a sine wave cut to disk is proportional to the speed of the turntable - the faster the turntable revolves, the longer the inscribed waveform on the record.
2. A different playback speed for the aforementioned sine wave will yield a different frequency - a slower speed will decrease the frequency, a higher speed will increase frequency
3. Cutting speed and lpi setting determine the maximum recording time for the disk
4. The physical size of cutting and reproducing stylii dictates the upper frequency limit - if you want to cut and reproduce higher frequencies, you can cut the original signal at higher speeds (= longer wavelenghts on the record), and then also play back the recording at a higher speed. But you will have less recording time.
You must have mis-understood.. I am talking about High Speed Dubbing, like on a dual tape recorder. Speed up the Source Material, and the Lathe Platter to cut a song in less time..
THe major problem I have notice, is the frequency shift, when you play something faster then the frequencies move up..
This means tha a 10Khz tone cut at 33rpm, and played back at 78rpm, could move up as much as 5Khz or more...
so if your cutting head cuts a good groove with a frequency range of 20hz to 12khz, you would lose the upper high end if you sped up the source and cut the record at a faster speed.
There for, The real limiting factor is the head.. Pitches, Lead Screws, LPI, etc can all be adjusted, some scullys can cut up to 600LPI.. If the head is 20hz -12khz, it will always be..
