hi guys
am looking to change out the drive shaft in a fairchild platter and change it over to a spindle instead.
is there a spindle out there that will let me do this.
peter
Fairchild 524 platter
- petermontg
Peter Montgomery
+353(0)894926271
+353(0)894926271
Hi - If you're thinking about mounting the 524 platter on ebay on a 6N plinth that would be a pretty tough job. Every Presto platter and plinth set are custom machined to fit each other. The well in the plinth will not be a standard size. Also the 524 platter has a pressure fit shaft. It would be pricey to have it removed, turned to size and then pressed back into the platter. I would look for a complete platter and well combo or machining will be required.
Good Luck!!
- Kris
Good Luck!!
- Kris
- petermontg
Thanks kris.
it was just to build a TT with a custom setup mounted into a flight case for transport options and obvious protection.
if the shaft is pressured it would be a pain to sort out a spindle so?
thanks for the heads up on this.
Peter Montgomery
+353(0)894926271
+353(0)894926271
