cutting heads
- jessefreelance
cutting heads
whats the difference between
crystal cutting heads and magnetic cutting heads
is one better
does one last longer??
is one better
- Steve E.
- Site Admin
My Recordio has a crystal cutting head. I think it works by driving a current through quartz (?) crystal, which then vibrates. The stylus vibrates as the quartz does, and makes the cut. In a magnetic head, the oscillating magnetic current drives the vibration.
I am under the impression that magnetic heads can produce stronger signals and therefore louder records; I don't have first hand experience, however. Crystal heads also turn to powder after a while.
Guest
Guest
The rewiring I'm thinking of would involve drilling holes for tonearms, reducing or altering the power to the motor (to slow it down to 45 or 33 rpm), tweaking the amps. It's a "from-scratch" build idea. But I'm jumping ahead of what will be at hand pretty soon-- a Recordio 78 rpm. Should be fun! Hopefully West-Tech can help supply a cutter head if necessary. I can do the rewiring myself.
-doug
-doug
- ameisevinyl
mm MC crystal
i think you all know:
piezo crystal heads are the worst sounding...
folowed by moving magnets like the grampian...
and state of the art:
moving coil...
crystals (like used in old telephones) and very old pickup systems
dont have an linear fequency response...
moving magnets are more stable, the coils can be bigger because they dont have to be moved...so they wont blew so easily...
moving coils are better sounding because the moving parts are not as heavy...you dont need so much power to drive them...so you got less distortion...
äh maybe someone with more insight can correct me?
peace
mart
moving coil...
peace
mart
