- RecordLabelTroll
Building a Horseshoe Magnetic Mono Cutter Head (pics)
Hey,
I'm not currently making one but for those of you who want to check this out!
http://philcoradio.com/phorum//showthread.php?tid=1017
Its a Horseshoe Magnetic Cartridge but I feel it'll also work in reverse to cut
- RecordLabelTroll
Re: Building a Horseshoe Magnetic Mono Cutter Head (pics)
You can also probably use the info and research to make something more of the modern stereo pro heads, now that you know the basics.
i bet if the coil and spring are strong enough you could cut with this pick up, has a VERY similar design to old presto and RCA heads...
- dubcutter89
Yes, those old pickups can be used for recording. I have a book that suggests using a pick up if your budget is tight...
Principle is the same, but there some differences to real cutters. Stiffer springs, stronger coils...
But might be good for some lofi stuff.
