Soundscriber excecutive
tape
Post: # 28075Unread post tape
Wed Dec 11, 2013 5:54 am
hi
I have a somewhat (late) special soundscriber model - it's pictures on the disc pacakge, first pic here: http://www.ebay.com/itm/NIB-RARE-SOUNDSCRIBER-SOUND-SCRIBER-DICTAPHONE-RECORDING-DISCS-30-MINUTE-/111233888197?pt=Vintage_Electronics_R2&hash=item19e60e6fc5
Working fine - however lacks both cutting head and attached microphone / start stop controller.
Does anybody here know where to find a cutting head for this machine?
It seems quite different than the ones used in other models
thanks
tape
Re: Soundscriber excecutive
Post: # 28076Unread post tape
Wed Dec 11, 2013 5:57 am
emorritt
Post: # 28117Unread post emorritt
Mon Dec 16, 2013 11:41 am
It's a proprietary head with an embossing point for the plastic discs it uses. These machines show up on eBay in various states quite a bit. Shouldn't be hard to get parts from another machine.
And this is more like it: http://img32.imageshack.us/img32/667/27sd.jpg
tape
Post: # 28119Unread post tape
Mon Dec 16, 2013 3:33 pm
however, I have only seen the particular model on ebay once - and that was when I bought.
Could very well be one of the last dics dictaphones they produced.
Just have to wait and get lucky I guess....
emorritt
Post: # 28123Unread post emorritt
Mon Dec 16, 2013 9:12 pm
There were many disc based dictation machines - the Edison unit that used the red "diamond discs", the Gray Audograph with the blue discs and star shaped center hole, etc. Each had something unique about it so you couldn't swap supplies. I haven't messed with dictation equipment too much, but it might be possible that a head from and Edison or Gray machine could be adapted for use in the Soundscriber. The amp/recorders weren't all that different - just enough to prevent patent infringement.
recordboy
Post: # 39348Unread post recordboy
Wed Dec 30, 2015 12:11 am
Hello Tape
any progress on this machine?
http://www.davidbordwell.net/blog/wp-content/uploads/Joanie-SoundScriber-and-Pepsi.jpg
I've NEVER. seen one like that.
do u have pictures ov yours?
I'm VERY interested!!!
Thn
Cheers,
recordboy
grooveguy
Post: # 39419Unread post grooveguy
Sun Jan 03, 2016 7:37 pm
I think you're right, about that being the last embossing machine that Soundscriber made. It's a generation newer than mine, which I figure to be mid-1950s. Good luck with a recording head, I think the only answer is to find another machine like it. Adapting other heads would be a hassle.
Back in the 1970s I had interest in the Dictaphone 'belt' machines. By then they had been obsolete for at least 10 years, having given way to cassette-based recorders from the same company. I contacted a local Dictaphone sales rep who GAVE me three belt-type machines and a dozen boxes of belts. He was glad to be rid of them. Sadly, the innards from those were worthless for my experiments, but someone one eBay gave me $100 for the lot some 20 years later.
recordboy
Post: # 39727Unread post recordboy
Fri Jan 15, 2016 1:05 am
turns out i do know this machine XD
i know i have some more info about, yet having some issues findind them.
p.s. if ever u get fef up/"over it" i would GLADLY take it off you hands & give it a good home :)
pps
its big claim to fame was the way in which it was controlled.
Cheers,
recordboy
tape
Post: # 39761Unread post tape
Sun Jan 17, 2016 1:05 pm
unfortuneately no progress on mine.
It was missing the embossing head, but more importantly the attached microphone that also serves as start/stop etc.
By short circuiting two holes at the mic in I was able to start it - but without cutterhead no progress.
Detailed patent with drawings can be found at patents online
recordboy
Post: # 39770Unread post recordboy
Sun Jan 17, 2016 4:38 pm
Hi Tape
Yes I've seen the patents & was going to post them, then though you must already know about them, seeing as you know what the head looks like.
yeah its VERY simular to the edison design ov that time (the voice writer). VERY complicated design. All STUFFED inside very strategically.
beest ov luck.
cheers
Cheers,
recordboy
tape
Post: # 64198Unread post tape
Sat Feb 17, 2024 5:33 am
many years later - some pictures of my model. Is that not a beatyful machine??? :-)
I will try to bring it back to life somehow. I have NEVER seen the model for sale or any pictures of it online other than the joan crawford commercial.
grooveguy
Post: # 64204Unread post grooveguy
Sat Feb 17, 2024 9:37 am
I'll bet that, by the time this model came out, tape was taking over in the office. Pity, it is a beautiful machine!
Tognabalogna
Post: # 64535Unread post Tognabalogna
Sun Apr 07, 2024 1:12 pm
hey tape! I found a Soundscriber Communicator that seems to be of the same era, but haven’t pulled the trigger on purchasing yet because I wasn’t sure if it was a real embossing machine or maybe a magnetic disc recorder… it’s very similar to your machine, so maybe we can help each other out. Can you send me the schematics you’ve found when you have a chance?
grooveguy
Post: # 64537Unread post grooveguy
Sun Apr 07, 2024 2:17 pm
Good find; I'd get it if I were you. 99% sure that it's an embosser, unless Soundscriber had some 'crossover' models between technologies, but I am not aware that they ever did mag-sheet recorders. Best to build electronics from scratch, rather than work with circuits optimized for voice. Somehow I got the EQ wrong on the one I hotrodded, too hot on the bottom-end. But here's a sample of what can be done, in this instance embossing on a discarded CD-ROM.
https://www.dropbox.com/s/425hx8xo8pzoh09/SoundScriber.mp3?dl=0
tape
Post: # 64561Unread post tape
Wed Apr 10, 2024 3:28 am
it's exactly the same as mine ! just pm me for schematics
tape
Post: # 64562Unread post tape
Wed Apr 10, 2024 3:29 am
whoops, no not the same, sorry
Tognabalogna
Post: # 64567Unread post Tognabalogna
Wed Apr 10, 2024 10:39 am
pm’d you! Looks pretty much identical sans the mirror (wouldn’t want to dictate an important note with spinach in your teeth), especially close to the ones in the ads posted upthread. Would be curious to source an old catalog with the various models available at the time, if such a thing ever existed.
Tognabalogna
Post: # 64568Unread post Tognabalogna
Wed Apr 10, 2024 10:42 am
this sounds great! Much better than the “telephone” quality I was expecting. would love to hear how you hot rodded it—did you build your own amp circuit to run a line signal through, or just bypass completely and use an outboard amp?
grooveguy
Post: # 64569Unread post grooveguy
Wed Apr 10, 2024 10:52 am
Hey, TognaB; here's a link to a write-up on the project.
https://www.schlockwood.com/_files/ugd/aee96f_180a574b56ae4b6b8b301596b5a26719.pdf
tape
Post: # 64577Unread post tape
Fri Apr 12, 2024 7:16 am
interesting!
