chip removal for Vinylium owners
- bumbinstien
Hi the title says 'chip' but im still cutting lacquers. Just started actually & have cut a few. I made this chip jar rig with some tubes & a hand held vacuum but i gotta stand there & try to catch the lacquer strings with the little tube (sometimes bumping into the cutter!). Anybody care to share a method of mounting a tube to the Vinylium cutter chassis? or any other tips? im sup prized that i didnt break the sapphire yet.
- bumbinstien
Re: chip removal for Vinylium owners
may be this is the wrong forum for this/ may be i should have posted this in the newb section? sorry about that.
- dubcutter89
HI!
Normally you want the chip tube to come from the backside of carriage to the cutterhead (looking to the cutting face of the stylus) like on neumann systems.
maybe there are some screws, holes, angles etc. you can mount your suction tube on, or maybe drill a hole or use some hot glue...
theres a vid of a kingston machine with chip suction but you cannot see too much...
Lukas
Lukas
- alexsation
Hi bumbinstien! I had such a problem, I am have long suffered very and messed least 20-30 lacquer discs. In a result I performed a miracle and now each record for me a pleasure!
I hope my experience will help you!
