Vinylium VC200 dummy motor HELP
sprout23
Post: # 33295Unread post sprout23
Tue Jan 27, 2015 11:55 am
I have a modified VC200(red faceplate) and need to make a dummy motor for it to get it going. I don't have the Vinylium overhead. I know to make it is just a couple resistors and maybe a capacitor and I'm not sure where it would be hook up to inside the VC200. Any help would be appreciated.
THANKS
Jason
The Shank
Re: Vinylium VC200 dummy motor HELP
Post: # 33296Unread post The Shank
Tue Jan 27, 2015 12:29 pm
Flo Mayday Mayday!
http://www.myshank.com
skype : steven.myshank
* Resharpening services
* Blank records
* Cutting lathe
* Cutterheads - HeLiX23
flozki
Post: # 33307Unread post flozki
Tue Jan 27, 2015 7:53 pm
yes simple
between pin 1 and 14 on the db25 connector. beep that out down to the kingkong (controller board of vc200. the one behind frontplate) there is a 4 pin connector.
on the 4pin connector
it between Pin3 and Pin4
Pin1 is Endswitch
Pin2 is GND
Pin3 Motor+ VMotor PWM Signal
Pin4 Motor -
you need
470 ohm resistor
470uF-1000uF Cap 25- 35V
22 ohm 1W Resistor
so between pin 1 and pin 14 there is a 470 resistor // 470-1000uF Elko Minus of elko faces Pin 1 and that goes over a 22 ohm resistor to Pin 14.
sprout23
Post: # 33344Unread post sprout23
Thu Jan 29, 2015 6:02 pm
Flozki, that worked great, thanks for your help, I did have a few troubles at first because my db connector doesn't go directly in the vc200 like others, mine has seperate xlr hookups for the feedback and seperate amp, but finding the 4-position plug on the front board got me to where I needed to be, and seems to be working how it should. I was hoping you could help me out with identifying a couple other hookups on the vc200 that I know I don't need for my setup but I'm not sure what there for, above one of them it says "head x out" and the other doesn't say anything but is also hooked up to the main board, I'll take a couple pictures in the next day or two so you can see what I'm seeing.
Thanks again for the help
Jason
